Home > Technical (L322) > Another alternator gone
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
So the Rangie would not turn over on Saturday morning, last used on Friday night. interior lights dim and more messages on the dash than you can poke a stick at.
Took the battery off Bosch S3 (110ah 700CCA) with a sticker saying it was new in January 2011. Now charged up and back on the Rangie
Got the engine started and the alternator is giving 15v unloaded, dropping to 11.45v with all the toys on. I guess this confirms the Alternator is gone (it has been whining like a banshee for 18 months now).
What alternator is best to go for? an OEM Denso unit?
Should I replace my battery? I don't think it is goosed yet, but it is down on CCA capacity 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #239807 4th Feb 2014 11:06pm
T24RES
I went for the Denso unit from CP4Less, using the home page voucher was around 180 posted. Although I've changed both the battery and alternator I'm not convinced I've fixed my battery flattening issues.
I think its still draining and am still investigating.
Post #239856 5th Feb 2014 1:17am
Went for the same, the original is a denso unit too. So should last.
Mine is giving the same voltages. Under and over charging voltages seem to scoobie the batteries too. So be prepared for the battery to have gone as well.
It is in at the moment having it done. First one my chap has done so have give. Him both rave instructions as t24res instructions as a starter for 10. Hoping it wont take too long....... There is nothing that can't be fixed with a hammer😜😜
Post #240016 5th Feb 2014 5:51pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Went to CP4Less and two Denso models showing for my FFRR. 401670210 and 401670220.Any idea which one? Also I can't find any voucher on the home page. Did I miss out? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #240024 5th Feb 2014 6:43pm
T24RES
Nomad,
The part numbers differ in that the belt pulley on the alternator has 6 or 8 ribs. Mine had 8ribs classified as 8pk. The voucher appears to be missing ATM Crying or Very sad Ian
Post #240030 5th Feb 2014 7:17pm
Nomad
Thanks! Mine has 8 ribs so now I just need to wait for the voucher to come back..... Whistle 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #240032 5th Feb 2014 7:22pm
Andy_J
looks like I need a denso unit then, will pull it out at the weekend and see if it is a 6pk or an 8pk.
Thanks for the pointer on the voucher 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #240106 5th Feb 2014 10:07pm
Have a look on lrparts.ru at microcat as there was a changeover vin, think i pit it in the other alternator q thread running, pre changeover seems to be 6pk and post changeover 8pk we thinks. There is nothing that can't be fixed with a hammer😜😜
Post #240135 5th Feb 2014 10:23pm
T24RES
Try this voucher at the checkout - SAVEME75 Wink
 Ian
Post #240368 6th Feb 2014 3:38pm
Martin
Site Admin
Guys, don't forget that site sponsor Advanced Factors supplies alternators: http://www.advancedfactors.co.uk/electrica...r-57-c.asp
Post #240373 6th Feb 2014 3:45pm
T24RES
I did check the sponsor 1st, however with the code its £190 inc postage, £28 cheaper than our man Big Cry Ian
Post #240374 6th Feb 2014 3:53pm
Nomad
Ian. Thanks for the checkout code - it does work Very Happy In the meantime I've found a local LR specialist who will fit an original genuine alternator for £485 if its three hours work but £55 per hour if its more. Does this seem reasonable? Should he offer me a fixed price or is it reasonable to say 'it depends'? He hasn't seen the car yet. He mentioned things like the possibility of seized bolts etc.. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #240396 6th Feb 2014 4:54pm
See if he will do the job if you supply.
Get the denso unit (original) form ecp or whoever is cheapest, and 55 per hour should be £165 to fit. So 365 in total..... There is nothing that can't be fixed with a hammer😜😜
Post #240416 6th Feb 2014 5:44pm
T24RES
Tempted to come and do it myself for that money Wink
Any decent garage will do labour only, the unit from CP4Less is the same. Just he'll put the profit in his bin. Ask for a labour only quote, I think it books at about 4.5hrs on paper. There isn't anything that will cause a problem, unless he's never seen a FF before. Ian
Post #240467 6th Feb 2014 8:28pm
Nomad
He's ok to do it labour only £55 plus the dreaded VAT per hour. Obviously he prefers to source the parts but in this case his price was not too far off the cp4less price. The issue is the number of hours. I told him it could be done in three hours (for a professional who's done it before). He was giving himself a little room to move. So the consensus is that 4 hours is probably reasonable. That's £264. So about £500 all in.
I don't have a big problem with the alternator at the moment so that's too much to pay for preventative maintenance. I just hope it doesn't pack up when I'm up in the Alps in March Shocked
Of course you could come down from Henley and do it for me or I'll wait until July - I can be sipping Champers at the Regatta whilst you're in the car park doing my alternator!! Whistle Rolling with laughter 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #240474 6th Feb 2014 8:44pm
