Home > Maintenance & Mods (L322) > PUDDLE LIGHTS VOGUE ON A 54 PLATE
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
Hi everyone
i have purchased some blue led bulbs upgrade for my puddle lights. POWERFULUK.COM;
i have watched there video on how to remove the puddle lights from a sport whereby with a small screwdriver, the whole module just pop out from under the light housing.
i have assumed the vogue lights do the same thing but when i try to lever out as per the video, it seems just the very thin lens is moving and seems very difficult to remove.
i have already cracked one lens trying to pull it out so i have stopped.
can anyone explain how i change the bulbs on these models, just incase i am trying to remove something that does not actually come out in the manner discribed
thank you
bob
Post #240304 6th Feb 2014 12:52pm
The procedure is described in the Owners Handbook.
" insert a small flat bladed screwdriver under the forward edge of the lens to lever the light unit out of the door"
They are very fragile but do come out as described above.
The screwdriver goes under the indent on the long side of the lens.
Post #240313 6th Feb 2014 1:12pm
BOBCUSSEN
THANKS for the reply, i have tried that by putting the blade of the driver up at the outter edge but all that pops out is the very thin lens ? i have tried both sides and already cracked on lens. the same thing happened on both sides, ie just the lens is lifting. do you think i am not putting the driver far enough in?
bob
Post #240350 6th Feb 2014 2:35pm
The clear plastic lens is the complete fitting. The bulb is mounted on the rear of the lens.
Once you get one out you will see how flimsy they are.
I just put the blade of the screwdriver under the lens edge, placed another screwdriver under the screwdriver at right angles to it and levered the lens out.
Mine popped out relatively easily.
Post #240354 6th Feb 2014 2:42pm
BOBCUSSEN
OH OK. ON THE VIDEO AT POWERFULUK;COM THE SPORT puddle light is a bit different. they place a screwdriver under the lens at the end and push it up and then it releases a tab and the whole unit pops out which houses the lens and the bulb.
ok i will carry on and try to get the lenses out
thats for the replies
best wishes
bob
Post #240389 6th Feb 2014 4:27pm
BOBCUSSEN
just to make sure we are talking about the same puddle lights, i am talking about the light that is up under the bottom of the wings mirrors, not the lights in the lower side of the door.
i assume also that it is just the lens that also comes out of the mirror Question Whistle Embarassed
bob
Post #240390 6th Feb 2014 4:30pm
We seem to be refering to different puddle lights Laughing I was refering to the ones in the bottom of the doors.
Never looked at the ones in the mirrors, looked too difficult to do without breaking anything.
Are you sure you don't remove the whole mirror cover to replace the bulbs?
Nothing in the Handbook.
Post #240392 6th Feb 2014 4:38pm
BOBCUSSEN
HI NO I think looking at all the other in the had book that the lens comes out the same way as the others? but it is a very thin flimsy lens i must admit.
i will ask to see if anyone has actually replaced the bulbs on the wing mirrors; perhaps a re wording of the post might be in order Laughing
but thanks for the replies
regards bob
Post #240418 6th Feb 2014 5:48pm
