Home > Maintenance & Mods (L322) > Built myself a towing electrics charger
Andy
Ordered a 7 pin plug off eBay (£3.99) and an Optimate fused lead (£2.99), cut the terminals off the leads and connected to the plug. Works a treat with my Optimate charger!
I can keep the battery topped up now.
Post #240397 6th Feb 2014 4:55pm
n1cktdv8
I have been thinkign of this since my battery error, do you have a pic or instructions. I'd need 13pin but have the male ready to roll Is this where I put the car details and a bit about myself ?........
Post #240399 6th Feb 2014 4:57pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
does that bypass the Battery module by charging on trickle via the tow plug ? Far to many gone...
Post #240400 6th Feb 2014 5:04pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
something like this ?
dont use car very often so this keeps it on a float charge
quick release in case her indoors drives off and forgets to unplug it first
Post #240403 6th Feb 2014 5:22pm
A1GSS
Thumbs Up Quick release good idea Laughing Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #240408 6th Feb 2014 5:26pm
Martin
Site Admin
Anyone after something like this can buy one from me: http://www.disco3.co.uk/shop/index.php?act...oductId=45
If you want to know why there are the price they are, they are a) fused internally and b) made splash proof - both of which use more time and materials than a 1 minute cut, screw and throw in a jiffy bag job Wink
You can convert a CTEK plug to quick release following the instructions I put up here: http://www.disco3.co.uk/wiki/Remove_lock_button_from_CTEK_plug
Post #240411 6th Feb 2014 5:35pm
n1cktdv8
Anyone got a wiring diagram please, I have a 16A Ring digital charger and the 13pin Plug but just need to know how to do it...I think there is a kit to purchase over on disco3 ? Is this where I put the car details and a bit about myself ?........
Post #240413 6th Feb 2014 5:37pm
Martin
Site Admin
I also wrote this, doing myself out of work Wink
http://www.disco3.co.uk/wiki/Charging_through_towing_socket
Post #240414 6th Feb 2014 5:38pm
Essential accessory for all FFRR owners with tow electrics fitted. Thumbs Up
Some day you may well need one to get in your locked, dead car.
Just don't keep it in the car. Laughing
Post #240417 6th Feb 2014 5:47pm
Andy
The optimate lead comes with a built in waterproof fuse holder. I simply opened up the 12s plug and using a diagram, connected it to the plus and minus.
Post #240867 7th Feb 2014 9:19pm
I built my own, buying parts off eBay and with some good advice on the electrical side from nicedayforit.
Not being a "trailer" regular needed to understand the white socket!
For flexbility, I put croc clips on the end, and use it mainly with my Ctek MXS 5, still working on creating a location for it to live "somewhere outside the car" so if the battery was ever to drain/fail and leave me locked out, it should be a simple case of connecting to another battery (once the lead is retrieved from its place of hiding) regardless of where I am. .
Post #240913 7th Feb 2014 10:46pm
ironhorse
i used a 12v cctv connector,it fitted very nice in the rubber grommet in trailer plug
i can leave the trailer plug in all the time without a trailing lead
and quick release if forgot about
Post #240917 7th Feb 2014 10:59pm
Should try and sell these to dealers......
Every lr in my local md showroom is hooked up to a ctek somehow fed into the engine bay from under the car. Mind you i suppose that would require them to have tow bars fitted. There is nothing that can't be fixed with a hammer😜😜
Post #240969 8th Feb 2014 9:35am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Interesting.
I have the Black single LR OE towing electric socket fitted (ie lights only, not the grey for fridge power ect).
Can I use this, or do you have to have the second socket electrics ( grey socket) to use this charging via towing electrics idea??
Post #243997 21st Feb 2014 1:15pm
Martin
Site Admin
No, you MUST have the additional 12S (grey) 7 pin socket or the single 13 pin socket. The black 7 pin (12N) socket does not have the connection to the battery.
Don't know why LR bother offering a single 12N 7 pin socket option Rolling Eyes
Post #243999 21st Feb 2014 1:18pm
