![]() | Home > In Car Electronics (L322) > How long 'til battery drain? |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
I have been suffering similar anxiety & am very interested in any views! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Sorry chaps there is in good answer to this. If everything is working as it should then it will last for way over 2weeks.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Should the car not "go to sleep" as it were, after a day or so, leaving minimum systems alive ?
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
50mA drain when asleep on my 2002 Vogue.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
....get yourself breakdown cover, that'll sort it. Ian |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
My solar panel wont do any charging in the front fag lighter only when i connect it to the rear boot charger does it charge. |
Just to expand on this, if you have a 020 battery, about 100Ah, this will last for 83 days until fully discharged. Doing that would kill the battery so I would recommend a reasonable safe limit of 50% capacity, so about 5-6 weeks of no use should be fine and I would consider a reasonable maximum before a charge. MC |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
If you are not confident about your battery staying the course when away there is a way round this which might be of use.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Why not just have the second battery in the boot and use it to jump start the car if the fitted battery is flat.
OK: my anxiety has eased... Thank you |
