![]() | Home > In Car Electronics (L322) > Bluetooth Funnies going on |
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
I have a not entirely unrelated problem. I-Phone 5 would auto pair no problem after entering the initial pairing code. Upgraded to a 5S and it no longer pairs automatically and I get the 'phone not attached' message |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
My 2008 used to do it all the time. I just used to go on my phone and say forget this devise and then repair it.
| jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308
Pairing seems to happen fine.
Cheers Jayboy, I'll give it a go and see what happens SDV8 AB MY 2019
Tried the un-pairing of the phone and also a physical disconnect of the Bluetooth module and no change.
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 269
My particular major funny is that if my phone (4S) pairs to the car - which it always does, without fail (thanks Wiggs) - if I get a phone call at home within about twenty minutes of getting in, the phone defaults to the car (which is now off) so I can't answer it. I have to turn BT off and on again to sort it.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
^ I have the same thing with caller ID , as for the phone staying connected to the car I think you are staying in range of the Bluetooth unit and it simply stays connected until the car goes to sleep. 2008 MY Supercharged
I think the unfortunate thing is that the car is never going to sleep unless the bluetooth is switched off on the phone..... very inconvenient if honest. It may be that the way my house is laid out means that in most cases I am quite near the car. 2011 Stornaway Grey 5.0SC Autobiography |
| All times are GMT |
