Home > Technical (L322) > SORTED: HDC inactive, lowering suspension
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I've done a search, but not found anything relevant.
Three times now I've had the dreaded bong with message 'HDC inactive, lowering suspension' with the warning lights coming on, and the suspension lowers to access height, but without any lights showing on the height control. In each case its been after a 25 mile drive, and two times for sure it's been very wet, not sure about the third time.
If I cut the engine then restart, it all clears.
Has anyone seen this? Could it be moisture related?
Thanks for any advice chaps. 2007 TDV8 Vogue SE Java Black
Post #240769 7th Feb 2014 2:17pm
guessing it could be the battery or a height sensor ..............
Post #240774 7th Feb 2014 2:27pm
Googsy
Any loss in power? Could be a split turbo hose as it frequently generates hdc fault message if split. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #240780 7th Feb 2014 2:33pm
taskam
Battery's a year old but fires up just fine without any bongs, even after fbh been running for half hour.
No loss of power, everything running sweet. I wondered if a sensor getting damp could trigger this. 2007 TDV8 Vogue SE Java Black
Post #240783 7th Feb 2014 2:38pm
we've had loads of rain so its possible...its dry today so is it doing it now?
Post #240803 7th Feb 2014 3:57pm
taskam
I'll be going out later today or tomorrow so will find out and report back. 2007 TDV8 Vogue SE Java Black
Post #240811 7th Feb 2014 4:19pm
Discotigger
I had the same thing happen to me just before Xmas, it had been raining hard and when one of my xenon lights blew up, I got the same. Once I'd replaced the bulb, it was fine afterwards.
Post #240851 7th Feb 2014 8:24pm
Boat.Buoy
2002 Range Rover Vogue 4.4 V8 Epsom Green
My guess would be low battery, HDC seems to be the most sensitive to low voltage of all systems on board, if my battery is even slightly low I get the HDC inactive warning when I start.
I'm going to be replacing my battery with one of these when it arrives in a couple of weeks;
http://shop.odysseybattery.com/p/pc1350-a
I've used Odyssey batteries for many years in my Defender, providing both engine starting and winching power. Nothing compares to an Odyssey, worth every penny of the investment.
Odyssey batteries hold their voltage higher during the discharge cycle, which should help enormously with our vehicles!! They also provide more Cold Cranking Amps (CCA) than any other battery of the same size.
Devon 4x4 sell them in the UK, I'm not involved with the company just a happy customer. Speak to Jake in parts if you need anything, he's very helpful.
Matt
Post #240854 7th Feb 2014 8:28pm
taskam
Thanks for your reply discotigger. The severe rain seems to be a common factor in this.
Thanks for your reply boat.buoy. I used to get the HDC error message (but without any warning lights), when starting up with my original battery. Since I replaced the battery with a Bosch S5 110Ah bad boy, it's been faultless even after intensive fbh use. This warning I'm getting now seems unrelated to battery voltage since it happens after a half hour run, but may be linked to large puddles I've driven through. I'll check the voltage tomorrow before I start up anyway to check. 2007 TDV8 Vogue SE Java Black
Post #240882 7th Feb 2014 9:43pm
taskam
Well I have had 4 trips since, and it's happened twice. Once was very wet, once was slightly damp so don't think it's moisture related now. Also get a message on the touch screen flashing up something to do with terrain response, but I haven't been able to catch it all yet.
Battery at 14v with engine running, so not voltage related. Appreciate any more thoughts fellas. 2007 TDV8 Vogue SE Java Black
Post #241871 11th Feb 2014 10:15am
taskam
Meant to add that the two warning lights that come up are the dynamic stability control and emergency brake assist that both stay at amber. Everything clears when restarting 2007 TDV8 Vogue SE Java Black
Post #241872 11th Feb 2014 10:22am
taskam
Found the reason for this in case it helps anyone. My steering wheel has always been slightly offset, which is annoying but I lived with it. Recently my track rod end ball joints have started to go, meaning that occasionally the steering wheel goes slightly more offset. This then seems to confuse the ECUs because from the steering angle sensor it thinks it's going round a tight bend and wonders how that's possible travelling at 70mph!
Confirmed this when I change both side tie rods and track rod ends and the alignment was way out....steering wheel 180 deg offset and the warning came up immediately. Got the tracking sorted and everything fine now. 2007 TDV8 Vogue SE Java Black
Post #248435 15th Mar 2014 12:20pm
Discotigger
Glad to hear it's sorted and cheers for the update info. Thumbs Up Bow down
The battery is always blamed for these types of problem, so who would have thought of the steering angle sensor! Shocked
Post #248454 15th Mar 2014 3:29pm
MikeC295
2006 Range Rover Vogue TDV8 Java Black
I had this exact same thing on mine last year, turned out to be the steering wheel not sitting straight while driving in a straight line. Quite an easy fix with a 4 wheel alignment.
Post #249384 20th Mar 2014 2:46pm
