![]() | Home > Technical (L322) > quiet front pdc |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
the volume on rear ones are certainly adjustable but afaik the fronts are not..i would locate the 'bleeper' and see if there's any thing wrong with it..the WSM should help you look in the right area.. |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
How do you adjust the volume Stan? Is it with the iid?
correct Ian, the iidtool can adjust the volume on the rears..i increased mine so i have no chance of reversing into anything now.. |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70
I bought a vehicle with a similar problem once, turns out the previous owner must've thought the beep was a little loud, and covered the unit with some foam/sound deadening! Removed and all was well.
| manxaircrest Member Since: 17 Jan 2014 Location: Isle of Man Posts: 42
never thought that may be an option ...... the simple things eh .. ?? any ideas where the little blighter may be lurking before i go in !! |
Have a look under the steering column, just to the left of the interior light..
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
We have a Peugeot Van at work and the radio goes quiet when the reverse bleepers are on. You'd think that technology would be available in Range Rovers by now... |
| All times are GMT |
