![]() | Home > Technical (L322) > Turbo Gone? |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Firstly, welcome!!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
Since it's Sunday tomorrow and garages prob shut, I'd have a look at the crankcase breather filter.
Orch Member Since: 08 Feb 2014 Location: SP Posts: 12 ![]() |
Thanks for the responses guys very helpful.
If the engine is running fine, I'd swap the breather for the upgraded one and top the oil up.
Hmm. I'm really in two minds to be honest. On the one hand there's a chance that it's really gummed up, and fitting a new breather filter might bring her back to life. On the other hand I could be making the situation worse by running her afterwards to check. |
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi and welcome, smoke and squealing sounds like typical turbo symptoms to me. Be very very careful a runaway turbo usually ends in total engine failure. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Dont know if its possible to get a runaway engine with modern direct injection, fair enough with direct driven mechanical
essexfarmer Member Since: 04 Nov 2011 Location: Essex Posts: 51 ![]() ![]() ![]() |
I could be wrong here but I thought that a runaway engine due to turbo failure was caused by the engine running on its own oil rather than diesel. 12MY Black FF VSE
Found this description on wiki
I'm still none the wiser though tbh! I've been pondering this and my thoughts at the moment are fit the new filter, top the oil up then just let it tickover for a while. Hopefully this will give the turbo some much needed oil and may just rescue the bearings. If the problem has been cleared once the engine is warm it shouldn't smoke anymore. Then I might have the confidence to take it for a spin. If it continues to smoke whilst ticking over I'd probably shut it off and wait for the garage to diagnose further. Does that sound sensible? I'm hopefully that just letting it tickover wouldn't cause too much more damage if the turbo is already past repair? |
Orch, what I was trying to say is that when you get a runaway engine there is no way to stop it, if it's feeding on its engine oil it will continue to race until it either runs out of oil or melts down, it may be possible to stop a manual car by stalling it but not an auto. Don't want to worry you just clarify what I was trying to say. 12MY Black FF VSE
Thanks mate. That was my understanding of it but needed it clarified. That would be a disaster. It's an auto as well. |
To be honest, as a diesel auto driver myself, I find it quite concerning and baffling that there isn't some sort of air shut off valve in case this happens. Imagine this happening whilst out on the road in drive! brrr. |
They are all Auto's sir |
I thought they might be after typing that. Oh well, as it's not my car I've never researched them before.
