![]() | Home > In Car Electronics (L322) > For f**k's sake |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
I have some matches and petrol |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Already got the petrol thanks gone fishin' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
cant remember if you've replaced the battery or not but these could be characteristics of a low voltage battery.. |
Friggin same here parked the POS up yesterday went out today at 4.20 to go an errand , whirr whirr whirr , friggin battery dead ....
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I stick mine on trickle charge about every 3 or 4 weeks, as I don't travel far each day and watch tv in it for an hour a day.
Battery seems o.k, fired up lovely gone fishin' |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Check for water in the left hand rear compartment as this was the same problem in my daughters RR. Shorted out plug in the radio module.
Had just left the car at the side of the house since earlier , neighbour has just chapped the door to tell me all my rear lights are flashing on and off ..... |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Identical problems happened to my car. The next day everything worked fine, couple days later same problem. This went on over a couple of weeks. It was the LCM (Light control monitor). Bought a used one from a breakers £120. |
Ah well RAC called out earlier , spent about 40 mins with the car checked battery and such finally came to the conclusion that I have a 2.5 amp battery drain somewhere , so looks like I will have to get it booked into the stealers , this should be fun .... |
pulled out the lear amp in the back every thing works o.k lights etc but not checked the sat nav,radio,cd as the amp is out. I will check the connections on the pins later, "touch wood"
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
I had a Bluetooth module go down with water in the rear left apparently.
common problem, search ''water shedder'' |
