![]() | Home > Technical (L322) > Noticing black smoke when accelerating |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3921 ![]() ![]() ![]() |
The car seems to be performing OK but when I accelerate and it kicks down there is a cloud of black smoke behind me. This isn't foot to the floor type acceleration but just enough to initiate kick down.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35751 ![]() ![]() |
i've always been told to floor it a few times to get rid of the carbon, dunno if it works or not.. |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
You could check the two big turbo hoses at the front and top of the engine - one of mine developed as split and caused similar smoking 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
That's why it's called dieseasal! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8045 ![]() ![]() ![]() |
More details here |
I do get "engine System Failure" sometimes at start up but just put it down to low battery. Geoff |
Check your hoses to be sure could be low battery as you suggest. Present :2008 TDV8 HSE
At start up - it is probably battery related
Failing that check one of your tail pipes for a banana |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
You wouldn't get any smoke if you had a DPF - I don't think a 2007 TDV8 has one (a 2008 certainly doesn't).
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16367 ![]() ![]() ![]() |
Geoff, you don't get a DPF until 2011 (ish) sir |
godot Member Since: 03 Nov 2015 Location: London Posts: 2 ![]() |
Hi
Ouch !
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
A good argument for fitting a EGT gauge to measure temps at each exhaust manifold or dump pipe. ______________________________
