![]() | Home > Technical (L322) > Drivers memory seat |
You have memory 1234 buttons and 1234 keys... If your key you are using is key 3 for instance, it will set the seat to position 3 set in the memory. Set number 2 to your position, then if that doesn't work number 3 then 4...
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Thanks for the reply. So what I have done is set the three memory positions on the seat to my preferred setting so t shouldn't matter what key I have. Still when I return to the car, the seat has moved way forwad and all the settings are different I then press 1, 2 or 3 to get it back to the correct place |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i had a similar problem, it turned out that a homeless dwarf was opening up my car and sneaking in a kip! I caught him asleep one morning, and yanked him out of the car!. he said he wasn't happy. so I said, which one are you then?
Then it will be the seat ECU at fault |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Hi does this help ? It says how to set the memory on the seats; http://www.landrover.com/imagery/market/us...tart-guide |
I have just today after nearly 3 years noticed how the seat does this only sometimes. I could never work out if it was keys or different ways of locking or unlocking and all sorts of combinations of different things that would cause it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
you must have the 'vogue haunted' edition range rover.. |
WHATEVER YOU DO, DONT PLAY THIS SONG IN YOUYR FULL FAT!
