Home > Maintenance & Mods (L322) > 2012 Rear Led light activation with engine startup
nkc
Nigeria 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
Goodday all,
i have a 2012 RR, that i have been able to activate the front leds to come when the car is on but the rear leds dont come except when i use the parking switch button, which would normally activate front leds and rear leds, but using a faultmate i was able to get the fronts to be on permanently, is there a way to activate the rears, either by hard wiring or faultmate?
thank you 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool
Post #242461 13th Feb 2014 12:54pm
if the option isnt there from factory , then no..
may i ask why you want the tail lights to come on on ignition?
Post #242462 13th Feb 2014 12:57pm
nkc
just to complete the cosmetic gizmo since the front is activated, i might as well get the back activated, looks very cool 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool
Post #242463 13th Feb 2014 12:58pm
i think the 'scandinavian' drl setting might do that..
Post #242464 13th Feb 2014 1:00pm
nkc
hmmm, i thought that would also activate the lower beams?, which i dont want on, until its dark using the auto feature 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool
Post #242466 13th Feb 2014 1:02pm
you're probably correct on that....
Post #242467 13th Feb 2014 1:04pm
