![]() | Home > Maintenance & Mods (L322) > Fitting New Facelift air con controls to 2003 Vogue |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 166 ![]() ![]() ![]() |
Hey Andy, is the unit a different color than what is currently attached to our RR's? The PowerfulUK fella has videos on removing this unit and so forth on YouTube, that might be of some use to ya. And as far as I know, I think the knobs being switched around would be easier wouldn't it? Zambezi Silver Range Rover (2010 Autobiography Facelift)
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
Yeah I've seen the video's on Powerful's website |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
plug and play, i did mine a couple of years ago and everything works as it should just in a different place. |
dnbaker Member Since: 31 Dec 2012 Location: Tennessee Posts: 12 ![]() ![]() ![]() |
Same here. I swapped mine with a used unit with the newer knobs and everything works perfectly - definitely plug & play. Huge improvement in looks as well. 2004 RR Westminster 4.4 V8
Gotcha Andy, well I think I might dab in this as well if I can find a well priced unit. Zambezi Silver Range Rover (2010 Autobiography Facelift)
I spent the morning trying to fit this. No issues generally except the unit I bought wasn't working so back to the drawing board |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Isn't the suspension raise/lower switch different on later models?
Yes, completely different. The height control switch is a rocker behind the terrain response knob
Surely someone must know something about these units? I can't understand why the blower is no longer working |
I've done a few videos.
Exactly what happened to mine when I removed it the auto button when used manually just illuminates 3 lights and is stuck on auto.Did you get this sorted. I'm thinking looking at your videos maybe a battery reset is in order? Present :2008 TDV8 HSE
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Battery reset, check the diagnostics etc
I've not done a battery reset as such however I have had the battery disconnected to do a couple of other bits and it hasn't had any effect (I assume the re-set is just off and on?)..... I'll need to go down and see my mate who has the diagnostics kit
