![]() | Home > Maintenance & Mods (L322) > td6 remap |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
I used to have a V10 Touareg which I had remapped, 0-60 time went down from by 1s to 6s. Not bad for nearly 3 tons of car. Everything about the performance was improved. If I have another diesel I will be doing it again.
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 ![]() ![]() ![]() |
its supertuning.co.uk £200 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i had mine done by rapid remaps and like you mine was immediately more responsive and smoother but that only lasted about ten days and then it all seemed to go back to as it was....
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
The JE Engineering remap has even more power and torque, with about a further 50bhp and 100 torques over stock.
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I'm still toying with the idea of a remap but my only concern is the box!
I think the td6 box problem is more related to gear changes, this wears the box out over time and causes the problem, mine doesn't change gear as much now.
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
I've booked in with alive tuning on the first of march, I'll post the results afterwards. Bushy
Cheers for your feedback Monty. That does reassure me a fair bit |
Makes it a different car.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Been searching for TD6 remaps and saw your comment MJdronfield about the JE Engineering remap, is that the one you have? How do you find it? Still going strong? |
No issues. Very pleased.
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 ![]() ![]() ![]() |
Bushy, how did you get on with the Alive re-map ??? Semper in merda sumus, solum altum variat !!
