![]() | Home > Technical (L322) > Maximum Voltage |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
To all the boffins
Cheers
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Yes, but that's expensive.... I got mine in a maplin sale and I don't think I paid £30.. Previously..
Your one is 70 quid now in Maplins |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
Not necessarily the case;
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
very comprehensive info Matt, thankyou.. |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Am excellent description from Matt.
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi oldcro, the 18v ( to 21v ) marked on solar panel specs is the OPEN CIRCUIT voltage rating and really has little to do with it’s actual operating voltage.
Personally I would always try to keep the voltage range between 11-15 as an absolute maximum, most sensitive electronics will tolerate 10-16 volts. Batteries will start to get unhappy from 14.9v upwards.
I knew you boys would come up with the right answers.
Hi JAYBOY, you’ll be fine.
I really don't want to get into the particulars, but when you talk about 300a starting currents you are not talking about a continuous load and the effects are very much different.
Hi Boat.Buoy I’m not sure what any of your “info” is supposed to be about but your are making assumptions in a number of areas.
My friend we shall have to agree to disagree.
