![]() | Home > Maintenance & Mods (L322) > woe is me - coolant leak |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Hi All,
Heres a start but it will likely be something unrelated to the issue I had:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
if your coolant level was ok before then you've dislodged a pipe whilst doing the oil change.. |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
My leak was this after a rad change.. water pump bolt and O ring .
Sorry replied to whelshdragons orignal post
The altenators do like to spring leaks on earlt 4.4's too |
spent the last hour looking but no sign of any leaks |
with the engine running? |
yep and after switched off for a while also. |
strange that you have to add so much coolant after a relatively short drive..sometimes using kitchen towel tissue can find minute sprays.. |
I think this is a hangover from my oil change. Left of image is front of car looking from under near side wheel arch. It appears to be loosing about 1ltr every 20 miles.
Found it - back of the engine above the bell housing. Looks like the engine to changover valve hose/coupling.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Part number JHC000081.
Thanks Steptoe, Looks like the right part. |
