Home > Technical (L322) > Supercharged Coolant pump
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi Gents, after doing a fair bit if reading on here. I'm getting the reduced engine performance message this only appears after probably an hour of driving (sort of 80ish) it pops up. But if I sit at 70 it's happy all day long and the message doesn't show. This has happened a couple of times now.
The question is from reading up the supercharger coolant pump maybe wired backwards. And the remedy is to switch the wiring and install a new pump. How can I tell if it is wired backwards though?
Also I've read up about the same problem with the Aux coolant pump does this need to be done as well.
Thanks again
Dave. The difference between theory and reality is that in theory it will work.
Post #243112 17th Feb 2014 10:43am
Dave, fill in your car profile pal or you will be asked constant questions about age and model etc etc when posting questions on here... Thumbs Up
Post #243113 17th Feb 2014 10:48am
Av_dave
Good point it does make life easier I suppose. Just filled it in. Thumbs Up The difference between theory and reality is that in theory it will work.
Post #243116 17th Feb 2014 11:14am
dingg1
http://www.fullfatrr.com/forum/topic22717.html
see my post above for vin numbers affected
you can just repin the connector and it may be ok - mine was
(supercharger pump and aux pump is the same thing btw)
Post #243124 17th Feb 2014 12:24pm
Av_dave
That's great thanks I will check my vin this morning.
Dave The difference between theory and reality is that in theory it will work.
Post #243292 18th Feb 2014 9:39am
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
But how would you know if all the issues "have" been dealt with ?.
Post #243293 18th Feb 2014 9:50am
Av_dave
Yep as suspected my vin falls within the affected models. Will get a new pump ordered and the pins swapped to be on safe side.
Will the cooling system self bleed on these after I have fitted the new pump and topped up the coolant or is there a bleed screw?
Thanks again The difference between theory and reality is that in theory it will work.
Post #243294 18th Feb 2014 9:51am
dingg1
in most cases just repinning the connector to the correct orientation will sort out the issue
ie the pump will run in the correct direction - its been running backwards since the car was assembled without much issue , if you continue to get the limited performance message - get a new pump
you lose very little fluid , but there is a black bleed screw on the expansion tank if needed , just open a turn or so and run until up to temp and then close it back in when happy.
LR should have recalled effected cars IMO and sorted the issue out (was told by LR mine had no outstanding recall work needed so assume this item wasn't recalled)
Post #243382 18th Feb 2014 4:51pm
Av_dave
Thanks for that will report back as soon as it's done. The difference between theory and reality is that in theory it will work.
Post #243597 19th Feb 2014 10:37am
Av_dave
Just an update. I've replaced my aux coolant for a genuine Bosch one. The wiring was also the wrong way round on mine as per technical bulletin. It was a pretty straight forward job and only took around an hour.
Been using her for a couple of weeks now and she is running great.
Thsnks for the info
Post #249974 23rd Mar 2014 8:53am
