Home > Technical (L322) > L322 gone crazy!? ...water ingress playing havoc! |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Water ingress in front footwell could be either windscreen seal or sunroof blocked drainage tubes.The rear near side compartment with the sat nav, amp etc getting wet that could be a rear real not fitting nicely? to a rusty seam in the bottom of the floor in that area.
17th Feb 2014 1:34pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
I had similar issues with mine last year - sorted by a new windscreen.
17th Feb 2014 2:45pm |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 |
Thanks for the input Welsh Dragon, I guess I can blow the drains out with an airline?
17th Feb 2014 3:15pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16184 |
Rear leak will almost certainly be the boot seal... Top left hand corner will have the metal inner clamps expanded (run your hand around the top corner and it will have expanded) therefore no longer sealing to the lip... Approx £80-£90 from Dan or suchlike |
17th Feb 2014 3:21pm |
The front leak, wait for a dry day one day!!! Pour a small amount of water in around your sunroof then see if it runs out of the drains at the bottom of the A & B pillars |
17th Feb 2014 3:23pm |
Thanks for all the useful info chaps! I've had the dehumidifier running again today and it does seem better.
17th Feb 2014 6:22pm |
17th Feb 2014 7:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Don't use an airline on the sunroof drains, it'll probably blow the pipe off the connector and then you'll really have an issue.
17th Feb 2014 7:05pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
Leak in passenger foot well and the location of Body Control Unit will explain most of your problems:
18th Feb 2014 12:23am |
Thanks for all the suggestions, yes Weejock that would definitely explain a lot.
18th Feb 2014 9:30am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Those problems point to the BCU, as suggetsed by Weejock. Remove the BCU and leave it in the airing cupboard overnight. |
18th Feb 2014 11:24am |
yodaboy Member Since: 20 Feb 2014 Location: Teesside Posts: 3 |
I had a very similar problem with my L322 after having the windscreen replaced - water leaked in through a faulty seal & dripped on the steering wheel cowl & front of the dashboard. Loads of alarms - suspension, cruise not working, reversing lights, indicators not working. Dealer wanted to strip the dash out - ££££. I said I would give it a few days. Anyway, I pulled fuses out one at a time to see if I could clear the fault. When I got to the steering wheel heater fuse (fuse 9 on my car) - everything else worked again. I took the cowl off the steering wheel and a trace of water has got into the tiny connector at the very bottom of the block behind the steering wheel - a two pin plug that powers the steering wheel heater LED. With that pulled out & the fuse back everything worked (except the LED)! Dried with some canned air, plugged it back in and problem fixed! It was a tiny amount of water that had got in but must have pulled the volts down or shorted the input - that's computers for you!
20th Feb 2014 3:50pm |
Thanks for all the suggestions chaps, it gave me some great places to start.
22nd Feb 2014 9:17pm |
Oh and to top it off...the drivers door handle to mechanism cable snapped today!? |
22nd Feb 2014 9:41pm |
