Home > Technical (L322) > washer fluid
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
washer fluid
Washer fluids ..... I've always used whatever I could find, eg recently Halfords washer fluid.
Turns out, BMW's own washer fluid doesn't like to be mixed with anything else & as a result the wifes 3 series now has blocked washers ( appears to be blocked at the pump at the bottom of the reservoir ) Evil or Very Mad
Anyway, what's the situation with the LandRover fluid ( that I'm assuming my Rangy was filled with at its recent service) ? OK to be mixed or should I stick to their own OEM stuff ?
Post #243312 18th Feb 2014 11:18am
pld118
BMW MD told me in the past to be careful with what screenwash was used, I think they said use organic only or something.
This was one of a couple of links on the forum that made me buy LIDL screenwash, for the winter at least, and several months in, all I can say is it's excellent, safe in the knowledge it won't freeze (although a mild winter anyway). Not seen any "don't use it on the RR" posts:
http://www.fullfatrr.com/forum/topic21466.html?highlight=lidl
Post #243334 18th Feb 2014 12:13pm
i've used asda own brand without any
problems..
Post #243336 18th Feb 2014 12:16pm
Oh Stan.......................... Rolling Eyes Laughing
Post #243337 18th Feb 2014 12:24pm
well i have upgraded from normal tap water with fairy liquid added.... Mr. Green
Post #243338 18th Feb 2014 12:26pm
Prop
Here is one good reason to use some form of screenwash rather than just plain water.
http://www.nhs.uk/news/2010/06June/Pages/L...water.aspx
Post #243339 18th Feb 2014 12:31pm
never heard of that happening Martin...
Post #243342 18th Feb 2014 12:43pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
If you read the article you will see that the HPA (Health Protection Agency) is sponsored by Halfords Rolling with laughter
Post #243351 18th Feb 2014 1:02pm
Prop
This was from a few years back but the research did seem pretty conclusive. Testing vehicles that never used screen wash highlighted legionnaires bacteria in 1 out of every 5 washer bottles, but no cars with screenwash added had any legionnaire bacteria present.
By spraying the contaminated water onto the windscreen it was suspected that legionnaires bacteria would enter the car via the ventilation system as a fine mist or spray is produced when the screenwash function is activated. Actual figures for how many of the UK cases are down to this method were calculated to be approx 20%. I guess there is also potential to infect others that are not even in the car, as use of the screenwash function in built up areas will also release legionnaire bacteria with the potential to infect pedestrians, cyclists etc.
If you think about it your washer bottle through the summer months will be an ideal place for legionnaire bacteria to survive and live. Its dark and the washer bottles often pick up residual heat from the car engines etc.
A quick google search will bring up plenty of hits on this subject.
Post #243354 18th Feb 2014 1:07pm
