Home > Maintenance & Mods (L322) > Built myself a towing electrics charger
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Cheers Martin. Thought that might be the case.
I agree, seems useless except when towing the boat / horse-box as the previous owner must have done.
Post #244003 21st Feb 2014 1:32pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
easy fix if you dont want to spend money on new ecu and wiring harness
get a white plug and socket a length of 2 core multi strand 1mm flex, a blade fuse holder and fuse, wire it into the rear fuse box
it has a 12v feed straight to the battery,(big red cable under 50amp fuses)
all you need is live and earth .follow the standard wiring below
[img]http://www.fullfatrr.com/gallery/albums/userpics/14187/Ystradgynlais-Overland-Club-Ltd_Towbar-Wiring.pdf[/img]
Post #244026 21st Feb 2014 2:23pm
paulmoran2
Cheers Ironhorse..i'll take a look at that. Thumbs Up
I had to get a jump start from a kind passer by this morning outside Toys-r-us in Leeds....it doesnt look good when you have a "premium" car that has the bonnet up
SWMBO had a right go too! Big Cry
Post #244049 21st Feb 2014 3:31pm
ironhorse
sounds like new battery time and a charger system
check this place out for battery's
http://www.advancedbatterysupplies.co.uk/carbatteryvartasilveri1
£106.00 next day delivery spot on service
Post #244085 21st Feb 2014 5:54pm
paulmoran2
Cheers.
The battery and alternator were replaced under warranty 18 months ago so think there's a drain going on. will get the multi-meter and ammeter out when I get chance
but think it will still be a good idea to have the charging socket connected as you said just to keep the battery topped up ready for the heated steering wheel,screens, seats and kids tellys every morning for the 3 mile round trip I do each day......Yes I know that's also why the battery's probably Censored Big Cry
Post #244177 22nd Feb 2014 9:37am
