![]() | Home > Maintenance & Mods (L322) > Door lock |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Mine has autolock. The way it works is that once you get going it locks all doors and the tailgate. When you stop all doors and tailgate stay locked. To open all doors either push the open door button on the dash (next to the hazard lights switch) or use the key fob. To open an individual door double pull the door handle. 2012 5.0L S/C
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Not sure if it's the same as my earlier car, but mine auto locks at 10mph and stays locked. Along with all the other doors.
Ah, nomad got there first as I was slowly typing an essay !
if you have autolock then you do need to unlock the door with two pulls of the handle...mine had this and i switched it off with the iidtool... |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Thanks for all the learned answers, thought there was a problem? My wife's Disco 3 auto locks but doesn't do this |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
sounds normal |
Yes, all sounds like normal operation except the bit where it tries to unlock when you stop, but doesn't succeed.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6820 ![]() ![]() ![]() |
Yep, I asked this question when I moved from a BMW E60, which DID unlock when you switched of the engine.
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Mine had it on when I got the car but had it switched off soon as I could. I did not like it |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The funny thing is, you could have an 06 FF and an 06 plate D3 and the features work entirely different to each other... The auto locking on a D3 auto unlocks when you remove the ignition key, doesn't auto unlock at all on a FF (rubbish feature imho) so you land up having to press the unlock button every time you exit the car! |
