![]() | Home > Technical (L322) > TPMS!!!!! |
RoryM Member Since: 03 Mar 2013 Location: Ireland Posts: 51 ![]() ![]() ![]() |
Main dealer wont turn off my TPMS.... so bloody frustrating! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35803 ![]() ![]() |
get an iidtool and do it yourself [and other stuff] |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 also I use main dealer as have a landrover warranty but always run the diagnostics before it goes in and when it comes back out to see what they should be doing and what they have done |
Tyre pressure monitoring system not worth the hassle! Rory as said get yourself an iid tool and say good bye to the dealer |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Thanks. I don't think I have that do one less thing to go wrong. There is a difference between knowing your sh!t and knowing you're sh!t
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'll second all the above. They're a bloody nuisance and I got an IID specifically to turn it off.
also Rory, because the tpms valves corrode when you get the chance replace the tpms valves with normal rubber ones. |
Thanks guys, I kind of assumed I would get this sort of reply. IID tool it is then.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
A wanted post may help, they seem to fetch in the region of £150 then as long as the model you have is in the same bracket as the sellers (ie:2005-2009) it is £25 for a new licence. If the car is in a different era then its £80 to re-licence. Ian |
