| I fitted a replacement gear lever surround yesterday using the switches from my old tatty one and at the same time installed my PURE DAB radio with the control boxed under the cup holder.
 I connected all the connectors correctly to the panel and it was working in an early test (before PURE fitted).  Today the HDC doesn't work and I have had a couple of errors come up to say its inactive.  Also I don't get a warning light if I use the hand brake and the TV only works like if I am driving (even with handbrake fully on)  I am guessing that I have knocked off a sensor or disconnected a wire when putting back together.  I will have a look around tomorrow or over the weekend but any ideas on where the handbrake sensor is, what it looks like or other ideas appreciated. There is a difference between knowing your sh!t and knowing you're sh!t
 2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
