Home > In Car Electronics (L322) > ipod transmitter
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
ipod transmitter
In the boot of my FF I have an FM modulator (?) it sends the sound from the DVD to the radio so everyone in the car can listen to a film. It has a 3.5mm input so I bought a 5m male to male lead off ebay and was going to route this through to the front so I could plug in the ipod.
Just tested everything and it works but before I started routing the cable and taking the car apart I had a search around the garage as I had one of these
http://www.ebay.co.uk/itm/FM-Radio-Transmi...51b54976e5
that I used in the disco.
Anyway I found it plugged it into the power in the centre cubby box, tuned in the radio and connected up the ipod, it actually gave a b etter sound that the hard wired version so I'll think I'll stick to this for now, just need a new battery for the remote Cool 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #245186 27th Feb 2014 11:30am
T24RES
Sheep For the price of a meal deal i bought one for the boxster, worth a punt Thumbs Up Ian
Post #245187 27th Feb 2014 11:44am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Hi Paul
Do you have a picture so I can check if I have this input on my 2007 VSE.
I currently have a male to male 3.5mm cable plugged into the Aux input below the rear seat heat vents, running the cable up under the centre console (between the seats) routing up to the ipod holder that I have clipped to the side of the touch screen area (as per picture- white cable) but your solution seems far tidier and better for security.
Cheers. Paul
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #245198 27th Feb 2014 12:42pm
Paul_H
Hi Paul
This is in my boot
I think it's an after market thing as my FF is a bit older than yours
HTH
paul 2005 Range Rover Vogue with Supercharged Accessories
Post #245220 27th Feb 2014 1:18pm
paulmoran2
Cheers Paul...i'll take a look, but think you are right about it being an aftermarket item. Sad GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #245223 27th Feb 2014 1:22pm
SteveMFr
Site Sponsor
Hi Paul,
The Veba thing is def aftermarket. That little one in your ebay link is great. I have one of those too - and before I got my silly lightning plugged iPhone, it was a constant travel companion. Worked great in any rental car and charged the iPhone. For less than many knock off charging adapters alone...
I also have this thing
Cost 10+ times as much and works much worse - and no charging function.
If an FM modulator sounds better than hardwired, you have an issue, though. FM loses a not insignificant bit of the spectrum at both ends.
It is the easiest way to pipe in sound, tho.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #245325 27th Feb 2014 6:37pm
RR2008HSE
Louder always sounds better. Thats why A-B tests need to be carefully match. Ive noticed my ipod is quieter than the FM radio. That may explain it.
Post #245407 28th Feb 2014 5:25am
