Home > Technical (L322) > air Suspension fault
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
hi gang got problem with above think I might have a leak on front drivers strut.
came up with air Suspension inactive max speed 35 mph
put hawkeye on said to much energy required to raise front,
inflated with hawkeye all went up ok but drops over a few hours
active values are all inactive bar" front axle signal active"
lights on switch ok but wont rise or fall lights just flash (not all at the same time )
could this be a leaking bag or a stuck sensor.
any help ??
thanks in advance pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #244567 23rd Feb 2014 10:22pm
trainmanone
update............
on info screen says air suspension inactive........ self level suspension inactive max speed 35 mph
hawkeye fault 103 to much energy for regulation needed front axle sporadic fault
active values are all inactive except " front axle signal active"
11.7 bar in res but wont rise to off road or drop to access level......... have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #244711 24th Feb 2014 9:50pm
Can you get to off road height and do the wheelarch lift / soapy water to check for leaks in the airbags? If that is not it then a trace back along the pipework / connections, cross link valve behind the inner wheelarch, then onto the reservoir connections and reservoir itself. .
Post #244730 24th Feb 2014 11:13pm
trainmanone
the switch to raise lower only makes the corresponding light flash, doesn't physically alter the height,
when inflated with hawkeye can hear air from drivers front wheel area but that's been like that for ages and stops when at normal hight.
Post #244754 25th Feb 2014 9:03am
Spray the drivers side with soapy water solution and inflate with hawk eye Thumbs Up
May have been like it for ages but will only ever get worse sir Whistle Thumbs Up
Post #244765 25th Feb 2014 9:58am
trainmanone
well just been to car disconnect battery, fully raid with hawkey,yes drivers side front leaking at elevated level, so long as it lasts the next two weeks till pay day im ok
seams to be ok now at standard ride height
fingers crossed
when I get parts any one in the north west fancy doing job for me or helping willing to pay Bow down
Post #244771 25th Feb 2014 10:26am
trainmanone
yet another fault code " air suspension inactive" the fault code is 100 articulation validity fault, any ideas peps?????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #245399 28th Feb 2014 1:49am
You are going to keep on getting faults until you replace the airbag with a hole in it .
Post #245400 28th Feb 2014 2:03am
SteveMFr
Site Sponsor
Best place to buy struts AFAIK. We have no affiliation, BTW.
http://www.island-4x4.co.uk/suspension-par..._2837.html
The Dunlops had probs with the strut bearing a while back IIRC. Either go with the Delphi's (hardly more expensive these day) or make sure you ask about the probs.
And replace the pair at the same time.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #245427 28th Feb 2014 10:40am
trainmanone
will order strut on Monday, can only do one side at moment (cash flow not flowing lol) but will do pass side at later date.
had a look at your how to joe90 hope its as easy as it looks any tips welcome ,
hoping to do job on weds or thurs weather dependant
pete Thumbs Up have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #245621 1st Mar 2014 2:53pm
It is easy once you have done it! Will rely on the two big nuts at the hub playing nicely, they can be a bit of a fight, so ensure you have lots of easing oil/WD40 and a good breaker bar. It is worth removing the inner wheelarch for better access to everything. Have fun! .
Post #245626 1st Mar 2014 3:01pm
trainmanone
well praying for fine weather now ,thanks joe90 will keep you all updated
Post #245628 1st Mar 2014 3:15pm
trainmanone
well fun was had this morning, just love wacking bolts with a lump hammers lol.
any how two hrs. later all done no faults smooth running again
thanks for all the advice again guys
think we should have a meeting sometime in the summer
Post #246481 5th Mar 2014 4:58pm
