Home > Technical (L322) > What rating battery charger ?
Page 1 of 3 123>
steves025uk
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I am having trouble again with my FF starting, let me down twice recently with a one year old Bosch S5 uprated battery fitted.
I realise the cause, I don't use the car often enough and then for short runs, e.g. picking the wife up from the station, two starts and 2 miles in between starts.
If I am going to keep the car I need to get into a battery charging routine.
The chargers I have are either very ancient or newer but small.
What recommendations are there for a 'quicker charge' charger that I can use on a regular basis ?
Would the Ring 20Amp from Halfords at £79 do the job ?
Post #245469 28th Feb 2014 2:28pm
Charmer
Buy a CTEK.
You won't regret it.
Post #245470 28th Feb 2014 2:30pm
steves025uk
CTEK MXS10 Battery Charger around £100 from eBay, much more from Halfords. Is this the one ?
Post #245472 28th Feb 2014 2:45pm
Ctek MSX 7 is more than adequate.
Amazon have them for about £94.
http://www.amazon.co.uk/CTEK-Multi-Functio...s=ctek+mxs
Post #245473 28th Feb 2014 2:48pm
Charmer
I have got both.
I would recommend the MXS10 as it will charge the battery quicker. It is only a few quid more.
Post #245482 28th Feb 2014 4:23pm
Dolphinboy
Get the lidl or aldi (can't remember which) for £12.95. It has an auto switch to trickle mode when the full charge is reached as well as an auto off capability if it detects anything wrong such as a surge etc.
The other alternative is to put a second battery in the rear left cubby hole in the boot where the removable towhook goes. I have this and never get drained. Thumbs Up
Post #245483 28th Feb 2014 4:32pm
mjdronfield
I have the ctek Mxs 7 and am more than happy.
Didn't want the extra lead floating about that detects temperature on the mxs10. Looks like it would get in the way. More than happy to press a button if it's cold.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #245484 28th Feb 2014 4:33pm
ctek mxs 5 Thumbs Up
Charges everything in sight, even our big batteries
Probably finished now but there was a group buy over on the Disco forum offered up by Martin (£60) .
Post #245497 28th Feb 2014 6:38pm
steves025uk
Thanks to everybody, a CTEK it is then, probably the larger one as it would charge the battery quicker when it fails to start.
I notice you can connect a couple of permanent leads to the battery with a socket to plug a CTEK into.
This would mean I would still have to park the car in the drive facing the garage and mains socket.
Has anybody got any more convenient solutions ? like plugging into the 12V socket in the boot after making it permanently live or something ? I have seen the method of connecting to a towing socket, but I don't have a tow bar fitted.
Post #245601 1st Mar 2014 12:55pm
mjdronfield
Martin once posted a link to something perhaps on the Disco 3 forum, where you used a towbar electric socket, if you have a towbar that is. I don't.
Here it is ;
http://www.disco3.co.uk/shop/index.php?act...oductId=45
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #245604 1st Mar 2014 1:10pm
steves025uk
After further searching on this site, I found this:
http://www.fullfatrr.com/forum/topic23501....p;start=15
The main red lead in the fuse box in the right hand rear compartment seems to be the solution for charging convenience.
A Ctek ring terminal lead from the positive red terminal with an inline fuse and an earth connection, dropping down into the secret cubby hole below the fuse box would allow a Ctek charger to be left in place in the cubby hole.
The mains can then come in and plug in to the Ctek charger when required. Much better than facing the car in against the garage/mains socket with the bonnet partially open ?
Does this sound like a plan ?
Post #245617 1st Mar 2014 2:39pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Why not put the FFRR in the garage when charging the battery? Thumbs Up Rolling with laughter
Post #245619 1st Mar 2014 2:48pm
steves025uk
Because I am sitting in the 'ex garage' typing this while surrounded by amplifiers, guitars and amplifier building paraphernalia. I built a small 'lobby' at the front behind the garage doors for my car and golf related collection.
Post #245623 1st Mar 2014 2:53pm
drivesafe
Australia 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi Steve and I have a dual battery set up i the rear of my RR and I have an Anderson plug wired up for both providing power out for running accessories and to allow charging to go in when needed but why not just go with one of Martin’s Tow Socket Charge Adaptors.
Can’t get a simpler set up and you don’t have to open or even unlock the RR to charge the battery.
http://www.disco3.co.uk/wiki/Charging_through_towing_socket 2007 TDV8 Lux
Post #245637 1st Mar 2014 5:09pm
steves025uk
Because I don't have a towing socket Sad
Post #245639 1st Mar 2014 5:43pm
Page 1 of 3 123>
