Home > Technical (L322) > Is this...
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Is this...
Is this the coolant valve? and should it be ticking to the point you can here it in the cabin when the FF is at normal operating temperature?
When the heater fan is on you can here it, when the fan is off its stops.
You can here it loudly and vibrating when the bonnet is up, ( hot to when you touch it Laughing ) I'm I needing to worry as this looks a pig of a job to replace if it needs replacing.
Middle of picture coolant valve?
 If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #246229 4th Mar 2014 3:59pm
Welshdragon
Can any one help with this part?
Im after the part numbers for these please :-
page 193 numbers 16 and 18 ( V8 cooling system page )
16 - Auxiliary coolant pump
18 - Coolant valve.
http://www.landroverweb.com/Pdf-files/Manu...0Rover.pdf
Sorry I cant scan the picture of RAV in the post.
Thanks in advance. If it dont work.......burn it!
Post #246478 5th Mar 2014 4:28pm
Thumbs Up ... - .- -.
Post #246479 5th Mar 2014 4:43pm
Welshdragon
thanks Stan Thumbs Up
Just need the part numbers now Bow down If it dont work.......burn it!
Post #246517 5th Mar 2014 7:45pm
have you tried microcat..? ... - .- -.
Post #246523 5th Mar 2014 8:02pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
The coolant pump was nearly £100 when I brought one Big Cry 1994 softail full stars n stripes custom harley davidson
Post #246531 5th Mar 2014 8:39pm
Welshdragon
When I open microcat online 1 in the wiki it come out in Russian, I know my English is bad but Russian....well that's just Censored ! Laughing Laughing
I think the part number for the valve ( 18 ) is JQD000010
I think its the other bit I need though!
Edited, Number 16 is part number JJK000010
Seems a few of us have had this problem! Whistle Whistle If it dont work.......burn it!
Post #246556 5th Mar 2014 10:36pm
