![]() | Home > Maintenance & Mods (L322) > MPG has dropped a lot - any suggestions? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I don't know what's wrong with it but i do know thats its not right.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
First thing I'd check would be the two big turbo hoses at the top of the engine - check for splits, a common problem
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I had two things wrong with mine one has been mentioned the other hasn't.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Very good advice above |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
^^ Sticky rear caliper - I've had it on both I've owned . . .
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 55 ![]() ![]() |
I'm going on a longish drive this morning, so I'll check the wheel temps when I arrive and report back! |
If your calliper is starting to seize, i would suggest not going on a long drive!
I did check the wheels for 'hotness' after the school run this morning, so was pretty sure I was on safe ground going on a journey!
