![]() | Home > Technical (L322) > HELP :( this is doing my head in |
Needle Member Since: 08 Dec 2012 Location: Aberdeen Posts: 51 ![]() ![]() |
Ok so now I have no first gear or auto ?, if I start off in 2nd then switch to auto it moves but keeps telling me to switch to manual to neutral |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
I know its endemic, however sounds like battery |
A brand new battery a few weeks ago aswell as a new alternator |
Sorry Needle, cant help. i am sure someone will be along soon |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Possible one of the problems is with the speedo sensor which from memory is on one of the rear wheels. Worth a search.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
I had a similar issue, but no gearbox stuff. Was fine, then all the dash lit up with no speedo signal, no hdc, abs etc etc.
^^ not going mad then, knew id read it somewhere! |
mjdronfield you r a legend !! , that sounds like the exact symptoms im getting even to the steering , ordered a ring just incase ,will keep you informed , thanks |
You are more than welcome. Its what the forum is for.
