Home > In Car Electronics (L322) > Parrot 3200 install
jeffridj
United Kingdom 2003 Range Rover Vogue 4.4 V8 Alveston Red
Parrot 3200 install
Before I re-invent the wheel I thought I'd ask if anyone has installed a Parrot 3200 in the Vogue.
I currently have a Gen 5 bluetooth ulf that is not compatible with my new phone (Motorola Moto G). Until I find a compatible ulf at a reasonable cost, I thought I'd install a Parrot 3200 as I already have one hanging round.
I was hoping to use the existing mic and install the blue box in the LH rear compartment and extend the screen wiring to the dash. Any comment would be great, otherwise I'll try and document things as I go along. 2003 4.4 V8 Vogue
Added Tow Bar, Reversing Camera, Freeview box
Post #247305 9th Mar 2014 11:44pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I recently contacted Parrott UK Technical Team as I had some questions about an installation I was doing on my wife's car.
They are really helpful and knowledgeable (they are guys who have installed these out in the field at the sharp end so they have lots of helpful advice). If you go on the Parrott website you can get the number, you will also see that the FF is not confirmed as compatible.
Funnily enough I'd been thinking whether the MKi9000 would be a good solution for those without an Aux socket and wanting an iPod solution......
Let us know how you get on. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #247313 10th Mar 2014 8:52am
We have a company install ours but i do remember A, the iPod Parrot kit could not be installed in the rear left corner for some reason? Rolling Eyes And B, when they install ordinary bluetooth kits for us, there is a dedicated piece of loom behind the L.H. wood panel next to the heater controls (passengers right knee panel) which has un-ampified speaker wires in (a must when installing phone kits apparently) and no need to run wires to the boot either Thumbs Up
Post #247317 10th Mar 2014 9:25am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Re: Parrot 3200 install
Parrot... don't bother. An unmitigated piece of Censored . Had a kit professionally fitted to my 2003 FFRR. It works when it wants to. The phone sound comes from the speakers but you have to wack the volume up to full tilt to hear it which is great when the call ends because if you don't turn it down quick enough......
The iPod connection is pointless as it to struggles to work with the command tool that comes with the kit and the screen for my kit , the Parrot Mki9100 is so small and dark it's unreadable unless you can mount in 12 inches from your eyeball.
Post #247331 10th Mar 2014 10:32am
jeffridj
Davek - Not sure why your Parrot kit is not working well, but I've had the 3200 in 4 different cars (one a rag top) and they have all worked very well. I've never put one in a FF so I'll post how I get on. Will probably start having a look at it tomorrow. 2003 4.4 V8 Vogue
Post #247424 10th Mar 2014 7:49pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I'm still planning on putting the 3200 in my 02 FF.
It'll be interesting to see how you get on.
Post #247427 10th Mar 2014 8:02pm
DaveK
Think it's something to do with the Parrot kit being unable to cope with the standard sat nav/entertainment system fitted as standard to the Rangie. The firm that fitted it made claims that it just doesn't live up to. Save your money !
Post #247447 10th Mar 2014 8:47pm
jeffridj
No money involved I have a few spare Parrot kits hanging about so I'll give it a go. It's bound to be better than the Gen 5 ulf that I've got at the moment. That doesn't work at all with my phone. I have to use an old phone just to "please" the stupid ulf. 2003 4.4 V8 Vogue
Post #247452 10th Mar 2014 8:57pm
DaveK
Glad you're not parting with cash ... I can't rubbish the Parrot stuff enough.
Post #247476 10th Mar 2014 10:42pm
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
I put a parrot kit in mine works perfectly fine but it's not intergrated into the stereo at all.
Separate mic fitted near overhead light unit.
Speaker in the centre of the dash used for parrot only.
Speaker disconnected from stereo system, not really a music buff so not bothered about the loss of one speaker
Post #247484 11th Mar 2014 7:48am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Another Parrot 3200 in my FF, works fine with me Mr. Green .
I have had no problems with it. I didn't install the parrot as it was fitted when I picked the FF up so guessing the previous owner had problems with the factory fit phone system.
I have since taken out the brick of a phone out of the cubby box and now have a little more room for my phone to sit there Very Happy If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #247486 11th Mar 2014 8:14am
Welshdragon
You obviously have never seen just how antiquated the early phone systems were Whistle Whistle Whistle
Had to put a sim card in the car for that phone to work Shocked
That'll be why yours has a Parrot sir Thumbs Up
Post #247488 11th Mar 2014 9:08am
Welshdragon
Thumbs Up Thinking about your not wrong, even the sat nav in 2003 where ......ere c Censored p , hence in mine I have not even bothered replacing the disc. If it dont work.......burn it!
Post #247495 11th Mar 2014 9:59am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Just thought I'd chip in - I've got the Parrot 9200i. A wonderful bit of kit - the volumes that Dave mentions can be easily sorted by selecting the level using the parrot rotary controller.
I use it all the time in the car to listen to music, originally from an iPhone and now from Android phone. It just works perfectly all the time.
If it's not working correctly, then it's been installed wrong somewhere down the line. I've had the same model 9200i fitted in 4 different Range Rovers - including the current FF with DSP - and it's something I'd never be without - when I get in a car without the functionality of the Parrot it feels like I've gone back in time. even newer cars fitted with all the bluetooth bells and whistles don't seem to work half as well as the Parrot.
Post #247545 11th Mar 2014 3:06pm
jeffridj
OK - did a few tests today and found the following
The mic in the car works fine with the parrot, I just ignored the shield and connected the other two mic wires to the parrot and the mic volume seemed fine. Wires on old 54 pin connector - 52 and 54
The mute from the parrot does indeed mute the radio in the car by connecting the parrot mute wire directrly to the mute line. Wire on the old 54 pin connector - 29
The line output on the parrot is too low level for the input on the car. Wires on the old 54 pin connector 17 and 18
I had a quick try connecting the high level output of the Parrot to the same wires and the levels appear to be much better but I need to do some more checks another day. 2003 4.4 V8 Vogue
Post #247580 11th Mar 2014 5:59pm
