Home > Maintenance & Mods (L322) > Help! - New car questions :)
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Morning all,
Just picked up an '07 4.2 S/C and have a couple of questions:
1) Will the tow bar and side steps from our '02 (also L322) swap over/fit?
2) The front seats don't seem to heat up despite being 'on', any ideas why?
3) The parking sensors don't seem to do anything despite the reverse camera working, is there a menu setting somewhere I need to change?
Thanks!!
Very Happy
Post #247702 12th Mar 2014 10:09am
The tow bar is different (exhaust hangers) but can be modified to fit... Electrics are different.
Front seats would need looking at before i could comment...
Parking sensors should work but i guess have a fault...
Where in Glos are you? Were in GL11 and could take a look if required? PM me if of interest sir Bow down
Post #247708 12th Mar 2014 10:42am
1, no the '02 towbar has different exhaust mounts, the side steps will but you need to take the metal brackets for the front mudflaps out.
2, loose connection under the seat.
3, select reverse and see if you can hear them click when you move in front of each sensor.
or an easier solution would be to go and see Craig at CTC who is right on your doorstep.. ... - .- -.
Post #247709 12th Mar 2014 10:43am
Duke Thrust
Have spoken with Craig, very helpful guy!
Post #247724 12th Mar 2014 11:21am
indeed Thumbs Up ... - .- -.
Post #247726 12th Mar 2014 11:22am
