![]() | Home > Maintenance & Mods (L322) > Gearbox Oil and Filter Change change on a TD6 GM5L40E |
| Semperfidlas Member Since: 27 Jul 2013 Location: Worksop Posts: 59
Hi All
Hi All
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Easy job, get the filter, gasket and new bolts from Dan@Duckworths.
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912
And buy a quality filter or else! Mine was a blue one! |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Make sure you can undo the filler before you drain the oil. |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
I wouldnt trust what LR say. ZF recommend servicing and they make the gearbox |
| cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186
did mine at the weekend easy job ,i was on a lift,took about 2 hrs,you do not have to use texaco oil,i used millers sp 111,i rang them and this was the best oil they do ,i also rang the gearbox company in hilton and he said it is not special oil needed .mine seems smoother now. |
You have to remember "changing" the transmission oil on a GM 5L40E as fitted to a TD6 only changes about 6L out of a total capacity of 9.7L in the system ie about 60%.
| paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502
I'll be doing mine soon and I plan to do 3 changes to really get it as close to all fresh as possible. My question is though, when do you change the filter? On the first or the last change? |
I changed my filter during the third change on the basis the first and second changes I considered as a flushing process.
Might have to put it to a pole!!! |
