![]() | Home > General > What to watch out for with a facelifted/converted FF? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I guess making sure all the electrics work as expected is a good start.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
might be worth reading through all the conversion threads and get an inkling to whats involved in doing one , this way you'd have an idea of what to expect..
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I would also suggest checking the headlight washers work correctly. I've read a few threads where the headlight washers don't work properly (or at all) when the facelift has been done.
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi, I have just completed a conversion and would agree with everything above, Check all lights pay special attention to rear fog light function. have a look at headlight connectors and see how neat the work on the wiring is also check front PDC works as it should, the area where the front bumper meets the curve of the wing is a little awkward to get right so look around that area and I think a good conversion should have the later inner wing liners fitted and not old ones cut to fit. hope this helps. |
maby66 Member Since: 19 Nov 2013 Location: Surrey Posts: 8 ![]() ![]() |
Thanks all for the tips, particularly on the wing liners - just the sort of thing I was looking for.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Yes it should be standard, but they do have working issues due to a control box fitted inside the steering wheel |
Craig when all these facelifts are old hat and the market has gone for converting you really must share the rear light wiring secret the curiosity is killing me, |
You sir, need to get out more... |
Figs and fig rolls spring to mind |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
By that time Craig will be face lifting 405's or re correcting messed up 405 OF or Kahns |
I recon on facelifting 405's as early as 2015 |
Thanks all - had to postpone the viewing, but may be going later in the week.
