![]() | Home > Technical (L322) > Front bumper removal |
As it happens im doing mine at weekend. Firstly open the bonnet and remove front grill. Also on inner wing liner each side you will see a bolt these need to be removed. Then you need to get underneath and remove the bolts that connect the undertray to the bumper. Once grill is removed there are a number of philips large head type screws that hold the bumper on. Once all these are removed you need to pull the bumper out from the side and pull forward. I would suggest having a second person hold the other end and have something soft like an old sheet underneath to rest bumper on . Be careful when removing as you need to disconnect the washer jet hose the parking sensor loom and the fog light loom. If you pull bumper away too quickly you risk damaging these connections otherwise. Hope that makes sense but its pretty easy really. |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
It is very easy - there is a thread on here if you do a search with a diagram showing the location of all of the screws (including a couple that were not obvious).
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
............and 3 hours to get it back on........... |
LOL - I actually surprised myself and it took less time to get it back on (although I did replace two screws as they were corroded). 4.2 Supercharged Vogue SE |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Hi Skot, Why so long to put back on?? Is there something I should be aware of?? Thx! Mike |
No, it's a pretty simple job by all accounts.
I'm very good at watching other people do it for me and chipping in with the occasional piece of technical advice though...... |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
It's about ten screws that hold it on, surprisingly easy.
