![]() | Home > Technical (L322) > how can i test my "cornering headlights"? |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
As above really, just wondered how you check that they are working? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35660 ![]() ![]() |
drive when dark and turn the steering wheel . ... - .- -.
The cornering lights next to the sidelight (same lens) |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6774 ![]() ![]() ![]() |
What Stan says then |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
Think You need to be under 18 mph or something similar when turning the corner - its in the manual |
Thanks boys
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
If you work it out I would be interested as I have not been able to get mine working. I have the bulbs and the extra ballasts on the lights and it looks like I have wires going to each pin inthe connector. Not been able to get them to light up yet as far as I can tell. Beginning to think maybe they were not fitted although one light shows evidence of past melting. There is a difference between knowing your sh!t and knowing you're sh!t
