![]() | Home > Technical (L322) > Fuel Burning Heater - Runs Cold |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
How much fuel do you have ? |
SHC Member Since: 21 Jan 2009 Location: London Posts: 5 ![]() ![]() ![]() |
A full tank or at least 3/4.
Not that then |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3804 ![]() ![]() |
perhaps its linked to your smell of fuel... |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
could be wrong but there is a sensor inside and outside the vehicle that measures temp so it heats up acordingly if you have a duff sensor that could be your problem or check the fuses |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Here's something you should consider (and I don't know if I am right or not) but I have a feeling the proper fuel burning heater was not standard when your car was made. I think that the timer only gets the fans going to ventilate the car on hot days for example.
You see thats why forum's are great you learn every day ![]() |
I copied this text from the RR L322 Workshop Manual:
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 860 ![]() ![]() ![]() |
Probably different systems, but we had a similar symptom on a Mercedes van and the fault was with the FBH water pump that had to be changed. |
dark.soul999 Member Since: 04 Feb 2009 Location: Bucuresti Posts: 9 ![]() ![]() |
The FBH its located on the passenger side (below battery). When running a “fan/blower” noise its heard in this zone. If noise stop after few minutes (after activation), FBH its defective. Go to dealer workshop to investigate cause. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
When was this a standard fit then? I'd like to know if ours has it, although we won't know till the weekend when we pick it up |
use the vin number and ring a dealer, they should be able to tell you Discovery 4 HSE
Just went out and had a play:
