![]() | Home > Technical (L322) > Voice recognition not working |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Could this be connected to the volume of the voice audio?
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Thanks Mike, have tried that but to no avail - |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35692 ![]() ![]() |
a battery disconnection could work and its worth a try.. ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When you press and HOLD the VC button the system should beep at you, as well as show "listening" on the dash.
I find a swift slap around her earhole sorts this problem out without too much hassle ![]() |
You haven't tangled with my SWMBO - you'd be welcome to try slapping her round the earhole - much cheaper end for you than assisted suicide |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 464 ![]() ![]() ![]() |
Quick question on VC, mine does not beep or work, everything else in the car seems to work (touch wood), wondering what is the correct fuse for it is?
try both.. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Does your sat nav work ok?. |
Yes the Sat-Nav and everything else electrical is ok as far as I can tell (touch wood again!).
Nothing wrong with the fuse on inspection. Will get another and change anyway on the very off chance. The steering wheel button works as tapping calls the last number on my phone, holding does nothing as mentioned previously.
BigEnglishWagon Member Since: 30 Jun 2020 Location: Wellington Posts: 11 ![]() ![]() ![]() |
The cellphone has been paired to the vehicle? |
Yes, my iPhone connects to the cars phone system via Bluetooth automatically, surprisingly quickly too.
