![]() | Home > Maintenance & Mods (L322) > 10 month old battery failure or something else? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Instruct them to change the battery under warranty and then see how it behaves over the proceeding week |
Exactly... |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
If it's not locked it wi wait even longer before going to sleep.
I think I get your point KP but this is a repeat issue with the car even when it has been on a good run, then gets parked in the garage, locked up and left overnight. The issue being the drained sounding anaemic start up. I'll take the advice of CTC and suggest that another new battery seems reasonable |
Agreed I'd still take Craig's action but they still need to get to the bottom of the drain |
Following on from my post when I queried whether or not, despite no systems being switched on (e.g even auto light switch set to the off position, no radio on etc) could simply not locking the car lead to a battery drain from systems taking longer to shut down and going to sleep:
If it's permanently live then it's possible but it would have to be a really poor one to drain that much power.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35749 ![]() ![]() |
the only live socket on yours Ryan is the rear one in the load area...did you check the obd port to see if its closed properly? ... - .- -.
@KP - Phone adaptor light only comes on intermittently when engine running. Point to note though, it's a rubbish universal adaptor that I bought in Tesco and it doesn't work properly to charge the phone, coming on and off when it takes the notion (you've often got to hold on to the phone and the connector to keep them mated so as to get any charge!). So maybe there' an answer to the problem in this reply?
thats the one Ryan. ... - .- -.
To be honest I avoid the cheap chargers as they are lethal in the long run. Get a proper USB cable for your phone and a belkin USB car charger and jobs a good en |
