![]() | Home > LPG > Moving LPG filler from towbar to bumper |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
It is doable but it's not something I would wanna take on, with out a gas guy assisting my other halfs farther is a gas engineer boiler etc and he is always saying about joints leaking etc from relocations etc
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi, The fitter who fitted that has no taste for sure |
Right, YES you can undo the flexi hose without the whole tank emptying out, BUT you will get a gas escape from the small amount contained within the flexi pipe itself.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
As they have both said above |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Had one in the bumper and got cracks in the plastic. The bumper is not strong enough to keep up with the force you need sometimes to get the filler in or out. I would not do it if I were you, but you are not me... so |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
I too would be leaving that where it is. Looks much better than in the rear bumper.
Actually. come to think of it, the P38's used to have them fitted in the 12S towing socket location so it might be possible to fabricate a suitable bracket for where the towing electrics go which is up behind the bumper.
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
Hi thanks for the replies guys, some great tips and info. I want to remove the tow bar completely as it's no use to me (will sell the complete unit after I've removed it if anyone is interested).
Mines here
This can b done but it's not recommend and a lot of installers don't like go threw the double skin
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
I cant remember if it was a P39 or L322 ( think was a 322) but I have seen on the trader the RR had the LPG filler where the petrol filler behind the flap as well....yes a tad tight but can be done.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
mine is on the top part of the side bumper. colour coded so not too bad to look at. with a cap etc. I remember reading on the lpg install rules, that a minimum height from ground is required, I think its 400mm. just in case some super lowriders out there try and tuck it underneath, and risk grazing it. the present position, seems ok height wise, but ring an installer for the best tips. its true it can break away and still only release a fart-full of gas in an accident etc, hence the need for the tank one way valve.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
My LPG filler is barely noticeable just behind the rear mudflap
Hi guys I'm interested in the option of welding a plate under the car to attach the LPG filler as an alternative to having on the bumper. Makes sense as will avoid cutting holes into the car, any tips on exactly where I should or shouldn't have the filler plate welded? |
