Home > Maintenance & Mods (L322) > Surging
mudknight
2003 Range Rover Vogue Td6 Java Black
Surging
Hi , can anyone shed light on this , when I put my td6 2003 into drive or reverse , sometimes she will surge forward , or reverse if in reverse , sometimes have to break hard and again sometimes she will stall ,, doesn't matter if she is cold or up to full temp ,
Post #250408 25th Mar 2014 12:11pm
might be something in these treads that'll help,
http://www.fullfatrr.com/forum/search.php?...rch_time=0
btw, whats the idle rpm like? ... - .- -.
Post #250409 25th Mar 2014 12:22pm
mudknight
The idle does change , nice and smooth sitting on 5
Post #250431 25th Mar 2014 2:21pm
just read your post again, you do have your foot on the brake when you select drive or reverse dont you..
and the idle should be around 700/750 rpm.. ... - .- -.
Post #250435 25th Mar 2014 2:33pm
mudknight
Yea foot on the brake as I select drive , my tick over is a little less than that ,
Post #250447 25th Mar 2014 3:07pm
With surging it could be sticky injectors I suggest you try a can of PREMIUM Injector cleaner like BG244 http://www.ebay.co.uk/itm/BG244-BG-244-Pro...1173617951
Post #250448 25th Mar 2014 3:10pm
mudknight
Have checked idle rpm , it's sitting at 750 , just done a little test , if I let it rev when it's surging , it revs up to around 1300 then it will come back down ,,
Will try that injector cleaner
Post #250519 25th Mar 2014 6:58pm
Sandyt
Might not be appropriate but had something similar on a p38 v8 it was a dirty maf
Post #250525 25th Mar 2014 7:05pm
mudknight
Sorry for my ignorance , but what's a MAF ?
Post #250540 25th Mar 2014 7:57pm
Mass Air Flow sensor... On your engine air intake Thumbs Up
Post #250579 25th Mar 2014 9:56pm
Stan, it won't come out of P or N without your foot on the brake sir Whistle Thumbs Up
Post #250580 25th Mar 2014 9:58pm
thats why i asked.. Wink ... - .- -.
Post #250585 25th Mar 2014 10:04pm
mudknight
I'm still none the wiser on my surging , thanks for your input though guys Thumbs Up
Post #250782 26th Mar 2014 7:50pm
sometimes in these situations you need to plug in a diagnostic tool to get the info where the fault is.. ... - .- -.
Post #250785 26th Mar 2014 8:17pm
mudknight
Think you may be right on this one ,, as it's intermittent will it still show up though ?
Post #250795 26th Mar 2014 9:00pm
