![]() | Home > Maintenance & Mods (L322) > Brake pad warning |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
The sensor is located on the inner pad. There's only two on the car (if memory serves it's the n/s front and o/s rear - but it could be the other way round, can't remember!) and you won't be able to see if it's worn without taking the wheel off or scrabbling around under the car.
R60EST Member Since: 08 Jun 2010 Location: Warrington, Cheshire Posts: 15 ![]() ![]() ![]() |
GKP , thanks for the reply. If I get new pads will one (per axle) of them come with a wire built in to connect to the sensor or does the sensor work without actually connecting to the brake pad.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Never changed my pads, but I think the sensor is seperate, but I most change them anyway as they are only about £10 |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Brake pad wear sensor wire is seperate item from brake pads (approx £12 inc Vat each from LR dealer)
Is it common practice to change the sensor at the same time as the pads or do the existing sensors get re-used
Last time I changed the pads, the sensor was ok - until, I tried to remove it from the old pad |
Ok , I'll head off to Euro Car Parts later and get everything I need once I've determined whether it's the front or rears that need changing.
Just a quick update, after removing the wheels to inspect the inner pads I found them all in good order . I did however notice that the wire leading to the rear brake sensor had chafed against the calliper and exposed the wires causing them to give a false warning. After following the advice give in an earlier post I chopped out the damaged area and joined the 2 remaining good wires together to complete the circuit. All is well again and the warning light and message has gone . I'll keep an eye on the pads and when the time comes to change them I'll do the sensor at the same time.
