![]() | Home > Technical (L322) > TD6 gives out quite strong diesel fumes when warmed up |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
sounds like a fault to me, either a fuel leak or your injectors are goosed.
SHC Member Since: 21 Jan 2009 Location: London Posts: 5 ![]() ![]() ![]() |
Thanks for this. I've not noticed any diesel on the ground and it only smells when the engines running. I'll have a look this weekend.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
My dad's TD6 developed a split in a fuel line but not leaking underneath, it stank of diesel though. Discovery 4 HSE
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
When you say diesel fumes, do you mean unburnt diesel smell or fumes from combustion?
Larry, Thanks for this. Its burnt diesel fumes and stops immediatly after turning the engine off. It happens at all temperatures, even when I haven't tried to use the fuel burner for weeks. I've also posted a thread about the fuel burner as well as it comes on (the fan runs) but doesn't heat up the car at all even at minus 2 degrees. I checked the fuse for the fuel burner and its OK (in fact the system/fan runs quite happily without the fuse in). Any light LR can throw on yours may help anyway (good luck with yours).
