![]() | Home > General > Mistake ? 2002 l322 v8 |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 on that enjoy |
Paulmeds Member Since: 18 Mar 2014 Location: Devon Posts: 34 ![]() ![]() ![]() |
Hi, also does anyone know anywhere to get the dash pixels fixed in the Devon area.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
Glad your getting there....
Well when I said I was getting there didn't expect the next bill from the garage !!!!
Blimey, that sounds a bit pricey, hope you get a bit more luck from now on.... Pete
Well clean bill of health didn't last long. Next problem, I have an intermittent problem with front o/s indicator !!! Changed bulb but still only works when it wants, any ideas please.
Indicator is probably the bulb holder, take it out, switch it on and wiggle it about if it goes off you know it's the holder...
Hi, thanks will try the bulb holder. EAS says inactive HDI inactive ABS light comes on etc. seems not to like going into motorway mode. |
Can you raise and lower it with the switch?? Is the led light on in the center of the switch used to raise and lower it?? Pete
Hi, can't move it, the light in the middle does come on so it is locked. After 15mins in services all ok, 10 mins back on motorway same thing happens. |
First thing I'd try is to rebuild the pump, sounds like it's not producing enough pressure, get one of these and it's a thirty minute job.... and only £25
Thanks, my first thought was compressor & the kit is much cheaper than new one. I am not a great mechanic so is this kit an easy fit for an amateur ? |
It's pretty straight forward, see this video and you can judge if you feel up to it....
hi, will watch video see what I think. thank you very much for the offer of fitting, very kind of you but I reckon the petrol to get there would buy a new compressor !!! again thanks for the help and information, I will keep you updated. |
