Home > Technical (L322) > Rear wiper motor - post seal replacement
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I just replaced the washer in my rear wiper motor as it was leaking on the wash - it all seemed to go fine and put it all back together and half a wipe later, it stopped working. It felt very tight putting the case back together into the new washer and I had to apply a lot of force to get it to seat.
I have checked front and back fuses and both are OK. I assume the motor is dead before I take it all apart again??
Many thanks in advance guys Thumbs Up 4.2 Supercharged Vogue SE
Post #251292 28th Mar 2014 9:31pm
my thoughts are that you might have put it back together incorrectly... ... - .- -.
Post #251293 28th Mar 2014 9:35pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
repaired mine done half a wipe of the rear screen and then packed up,scratched head for a bit un plugged it then plugged it back in and it has worked ever since
Post #251420 29th Mar 2014 7:05pm
Chauch
Ah, thank you - that gives me the pick up needed to take it apart again, cheers Thumbs Up 4.2 Supercharged Vogue SE
Post #251421 29th Mar 2014 7:48pm
Chauch
Very oddly - exactly the same experience, took it off, refitted it and the motor fired back into life!
Sadly still leaking even with the new washer so new motor ordered…. 4.2 Supercharged Vogue SE
Post #251533 30th Mar 2014 12:52pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
When I did mine the first set of screws I used sat slightly too high and jammed the mechanism on reasembly. Might be worth checking yours as you mentioned it was tight when you reassembled too. Smaller headed screws sorted it. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #251633 30th Mar 2014 10:38pm
