Home > Technical (L322) > Sunroof question
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Sunroof question
Had the sunroof fully open today ( well we get the chance at least once every year ! ). Noticed a long black plastic strip on the inside edge of the void it sits in, close to the windscreen side. Should that do anything ? I pushed it up with my hand and then back down again. Don't remember seeing anything about this in my owners manual, long since lost.
Post #251615 30th Mar 2014 8:42pm
wind deflector? ... - .- -.
Post #251616 30th Mar 2014 8:46pm
Vogue
Stan's right it is a windeflector, its supposed to be spring mounted though and flick up when you open the sunroof
Post #251617 30th Mar 2014 8:49pm
DaveK
ummmm. it didn't !! Better start investigation why. Hope the spring hasn't gone. Just checked Rave, no mention of it or how to remove/repair
Post #251618 30th Mar 2014 8:53pm
DaveK
Bit of manual up and downing with a blast of WD 40 and then some grease around the pivot points seems to have done the trick. Be careful though if messing with yours, very cheap and nasty and could easily break.
Post #251738 31st Mar 2014 3:28pm
