![]() | Home > Maintenance & Mods (L322) > How easy is it to remove a Tow Bar from a L322 |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Is it an easy job ... i.e. undo a few bolts plus are tow bars really worth much when taken off to resell ... ====================================
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Pretty sure you need to have the bumper off too but other than that bolt off. You will need the hangers which are removed when you fit the bar to put back on though. These bolt on where the towbar fitted, then unplug the wiring.
| Cryptic Member Since: 01 Apr 2014 Location: Manchester Posts: 63
And if he doesn't have it, I might. |
Will let you know , thats if i can be arsed taking it off and if it is worth the hassle ..... ( don't do hassle ) |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Mick can I have your wooden knob? Present :2008 TDV8 HSE
| S33MAF Member Since: 04 Feb 2014 Location: WC Posts: 216
Long shot but thirds if other two don't. |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
Bumper off Mick.
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Yeah right. You're married aren't you? |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Mick, rear bumper off, strip boot sides , remove rear crash bar, undo exhaust hangers, dis/assemble electrics, remove 4 x 22mm tow bar bolts (mind your toe's) replace original tow eye brackets x 2 and then put the rest back together |
| Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120
Mick
