Home > Maintenance & Mods (L322) > Brake Bleeding
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Brake Bleeding
Morning all, Have had the dreaded 'sticky piston' issue on the N/s rear calliper. New pair of callipers and pads on way from Dan (should be here later today) Thumbs Up
I will obviously need to bleed the brakes once I have fitted the new callipers, and as there is no evidence that the brake fluid has ever been replaced, I intend to do this at the same time. I have a Gunsons 'easybleed' kit, which I used to use all the time on my Defender TD5 - but that didn't have the ABS etc. etc, just a 'bog standard' braking system.
So, the question is, can I use the pressure bleed kit to bleed the system, or will it affect the ABS or braking system. Question
If I can't use it, then I'll have to get SWMBO to sit in the driver's seat and press the pedal while I am bleeding the system Big Cry (it's much easier with the easybleed, as you can do it on your own Very Happy 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #252109 2nd Apr 2014 12:19am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have just bled mine, probably the easiest car I have ever done.
You can get very easy access if you raise the suspension (May not need to dependant upon your alloys) and the easy bleed kit works well. There didn't seem to be anything complicated about it at all and mine is still stopping Very Happy 4.2 Supercharged Vogue SE
Post #252118 2nd Apr 2014 6:36am
+1 No problem using an Easy-Bleed system with an ABS equipped car, I used to do it all the time.
Much easier than using an "assistant" Thumbs Up
Post #252124 2nd Apr 2014 7:47am
+1 Thumbs Up
Post #252144 2nd Apr 2014 9:42am
Full Fat Ray
Thanks for the help guys Bow down , always good to know that other people have successfully manged to do what you are proposing. Thumbs Up
Calipers and pads have just arrived Very Happy BUT I'm on nights this week Big Cry
So, hopefully if the wet stuff stays in the sky tomorrow morning, I should have her back on the road. Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #252240 2nd Apr 2014 6:03pm
Post #252263 2nd Apr 2014 8:06pm
