Home > Group Buys > flip keys [New Order Oct 2014]
Sign Up
(28)
(58)
(18)
User Registered Confirmed
Stephen.12531st Aug 2013 2:19pm
andyleeds6th Sep 2013 6:53pm
DTaylor21st Sep 2013 5:12pm
Elduke7th Oct 2013 10:31pm
daveo27th Feb 2014 12:08am
gregh14th May 2014 9:33pm
gezzer152013th Aug 2014 3:44pm
Bunchy1001st Nov 2014 3:08am
dhallworth17th Nov 2014 12:26am
tony6623rd Jan 2015 11:53pm
47p217th Feb 2015 8:01am
Stomer Drl9th Apr 2015 8:19am
hex8th Jun 2015 9:38pm
J9022nd Jul 2015 8:57pm
socialrover17th Oct 2015 1:48pmsocialrover is confirmed
dolph3418th Oct 2015 9:21pmdolph34 is confirmed
freeforme7728th Dec 2015 6:44pmfreeforme77 is confirmed
prayer16312th Feb 2016 1:22pmprayer163 is confirmed
TrumptonDave15th Jun 2016 11:30amTrumptonDave is confirmed
kz355130th Aug 2016 9:20pm
Krams15th Oct 2016 6:58pm
tcmnorcal6th Oct 2017 2:21pm
seaneb7th Nov 2017 11:19pm
Quiff6th Aug 2020 6:57pm
abalanos5th Feb 2021 5:50pm
Steaky18th Feb 2022 11:28am
its me5th Aug 2022 1:20pm
yomchi8613th Nov 2023 10:00pm
Baldrick563528th Aug 2013 10:22pm
Mustard28th Aug 2013 11:27pm
MrP29th Aug 2013 4:21pm
willowzn30th Aug 2013 10:10pm
andy18030th Aug 2013 11:09pm
flipflop2nd Sep 2013 12:36am
RichTD66th Sep 2013 10:17pm
Tallsaj9th Sep 2013 10:08pm
glennhoward11th Sep 2013 7:58pm
kruger200218th Sep 2013 11:45pm
Simes19th Sep 2013 6:52pm
geordiefella8th Dec 2013 3:30pm
redshovel3rd Jan 2014 9:43pm
jak4807th Jan 2014 7:07pm
dazt_8515th Jan 2014 11:24am
cliffy8th Feb 2014 7:44pm
Winchester1018th Feb 2014 9:50pm
rej12th Feb 2014 8:47pm
mick-ne24th Feb 2014 11:22pm
steviebabes25th Feb 2014 10:19am
rads26th Feb 2014 2:47pm
dba1128th Feb 2014 7:37pm
RRIII5th Apr 2014 7:40am
Needle12th Jul 2014 8:48pm
jj29081st Sep 2014 8:44am
docjones23rd Sep 2014 10:31pm
Smegordead29th Sep 2014 7:55pm
Turnover30th Sep 2014 1:43pm
Roofer1st Nov 2014 7:43am
comports2nd Nov 2014 6:37pm
mgbgtv826th Nov 2014 8:46pm
Jaipo7th Dec 2014 8:40pm
chex3rd May 2015 11:26pm
shinchan2nd Jun 2015 5:05pm
Boydonegood6th Jun 2015 7:42am
DannyH8th Jun 2015 11:52am
Billydun3416th Aug 2015 10:20pm
zetjester14th Nov 2015 6:40pm
Mike.Boro18th Nov 2015 5:20am
davethomas8329th Dec 2015 3:24pmdavethomas83 is confirmed
MCM665th Jan 2016 11:37pm
Ohwhatalad7th Jan 2016 9:46pm
454awg27th Jan 2016 8:31am
Ollie_24726th Feb 2016 5:07pm
Big Tings11th Jun 2016 7:09pm
CY8816th Jun 2016 1:41pm
Wylie6619th Jun 2016 9:19pm
MatsonTAS20th Jun 2016 7:57pm
Donnor26th Jun 2016 6:28pmDonnor is confirmed
ErwinS19th Feb 2017 9:12pm
Rewmer24th Feb 2017 4:57pm
alfapat25th May 2017 7:09am
nebc10028th May 2017 8:54pm
L322 Newbie27th Jul 2017 7:18am
easylife10312th Oct 2017 8:16pm
biggirly119th Sep 2018 11:23pm
haaris19th May 2020 5:08pm
Mane_Ugle11th Oct 2021 10:52pm
ebajema28th Aug 2013 7:22pm
markpr28th Aug 2013 8:16pm
cstowe212028th Aug 2013 10:37pm
AKIS29th Aug 2013 2:24pm
jwclements12nd Sep 2013 3:36pm
duck109816th Sep 2013 11:15pm
Scottrx7tt16th Nov 2013 4:10pmScottrx7tt is confirmed
RangeK1D5th Mar 2014 12:20pmRangeK1D is confirmed
christoforos7th Apr 2014 2:34amchristoforos is confirmed
markskyline20th Oct 2014 11:51ammarkskyline is confirmed
Kaj28th Feb 2015 6:36pmKaj is confirmed
Ian c229th Dec 2015 9:58pmIan c2 is confirmed
rar11017th Apr 2016 12:23amrar110 is confirmed
beaudog1111th Jun 2016 9:34pmbeaudog11 is confirmed
csufy27th Feb 2017 4:40pm
Lukie24th Jun 2017 11:18am
jonasserra12th Jul 2017 12:07pm
muddycharles3rd May 2024 4:52pm
Page 20 of 36 <123 ... 192021 ... 343536>
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
PLEASE READ from daveo's post i guess you only have to ask Rolling Eyes Whistle
OK the keys will start going out, as stated it will be standard post, if you want anything quicker than you will have to pay the difference. For those of you abroad I will check and get back with some prices.
WARNING, when you start your car with the key make sure the transponder is with the key, don’t be tempted to just test it with the chip next to the key, as when the car rolls the security code if the chip is not in distance it will not be updated with the new code, this happens each time you start the car, do not introduce both chips to the car as this can also cause problems and lock the EWS and then your car will not start even with the original key.
Step 1...first thing is you need to make sure you can sync the key,
http://s266.photobucket.com/user/daveo1000...2544040538
procedure; all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, and then turn the ignition switch to position me and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again. If you cut the blade or glue it together before checking this and there is a problem with the board they will not cover it,
Step 2 ...spare blades at the moment are like hens teeth so make sure it is done properly, after the blade is cut check it in the door to see if it unlocks, if all is good and the sync is done then put your transponder chip in the key, next pop it in the ignition and start the car, let it run for a while then turn off..Job done, run around for a few days with a cable tie around it until you are sure all is ok.
Step 3... When gluing the shell together do not over glue as if it goes on the board and there is a problem again they will not cover it.
The new style keys come apart very easy and with a thin flat blunt point you can flip the back off,
this will expose the board that comes out and then you can remove the silicon plug and insert your chip,
replace the plug. Refit the board and clip the back on...Job done.
The chrome side covers do clip off for those that may want to colour code the key.
Ok, on the original land rover flip you will need to sync the key, you don’t have the flashing light to tell you whats going on so listen out for the doors lock and then unlock,
These keys are new and still tight; I like to double wind the spring to give that bit more of a flick.
Then you take the key apart it will spring all over the place, don’t worry...
You should have these parts... 1994 softail full stars n stripes custom harley davidson
Post #252228 2nd Apr 2014 4:20pm
daveo
thanks winchester..
all the info you need is in the thread as winchester has reposted, Scott you should of pm me and i could help you out, i try to keep up with whats going on and most problems can be resolved from reading through the posts
winchester i pop over to your mate and had two keys cut,spot on Thumbs Up
he will cut keys if you post them to him,
just a word or warning.. Exclamation Exclamation
even a professional lock smith can some times mess a key up so beware you have them cut with no guarantee that they will work,
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #252307 2nd Apr 2014 10:20pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Great info.
@Winchester; I will call the chap and most likely post the keys. Anyone got any idea if he would just want the blades or the entire key?
Cheers
Steve
Post #252310 2nd Apr 2014 10:40pm
Winchester101
Steve I don't know if you have his phone number but that is the way forward
I have his details if you need help
Thumbs Up 1994 softail full stars n stripes custom harley davidson
Post #252334 3rd Apr 2014 7:48am
Winchester101
Daveo
I'm glad he did a good job for you Bow down 1994 softail full stars n stripes custom harley davidson
Post #252335 3rd Apr 2014 7:51am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Confirmed one of the bmw key blanks work perfectly Smile just snap the black plastic off the top and file it to fit the flip key holder then make a grove to tap the pin through, charged me £4 for the blank, there on eBay as well 6 to 9 quid Wink Thumbs Up
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #252360 3rd Apr 2014 11:37am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Is it possible to take the blade from the original key and get it to fit in to the new style flip key in case the key cutter f....s up the new blade when he cuts it? There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #255544 22nd Apr 2014 12:35pm
rej
Any recommendations as too where I can get the new keys cut (all sync and locking unlocking ok). If it makes it easier I am happy to buy a couple of new blanks from whoever cuts it, either to use in the flip keys if they will easily fit or just to protect their income provided that they do a decent job and cut the blade properly so it works.
Live in Stevenage, Herts and work in Harlow, Essex
Winchester101, where in Essex is the place that did yours, as I could possibly pop out for an hour or two as they seem to know what they are doing. PM sent with my contact details in case you don't want to put details on the open forum. There is a difference between knowing your sh!t and knowing you're sh!t
Post #255579 22nd Apr 2014 3:51pm
Winchester101
Have sent a text rej
The guy is in Hadleigh bout 3 mile out of southend
If ya fancy a swim in the mud hehe 1994 softail full stars n stripes custom harley davidson
Post #255583 22nd Apr 2014 4:39pm
flipflop
Wales 2002 Range Rover HSE Td6 Alveston Red
At last I've found a key cutter who is more than willing to cut my key, 5mins and £9 later a perfectly cut key works first and every time Razz Razz . Only trawled south wales and the south west for the last 5months(off and on). For anyone in the south west area the place is Apricot keysmiths, Frome, Somerset
Post #257013 30th Apr 2014 3:06pm
RangeK1D
Canada 2004 Range Rover HSE 4.4 V8 Zambezi Silver
For making the 2010 key work, is this the correct procedure?
1. Remove transponder chip from original key
2. Remove board from new key
3. Put transponder chip into new key
4. Insert original key into ignition for pairing mode and keep new key with the original transponder chip right beside the ignition
5. Pair the new key during the pairing mode (with any other keys I have to pair)
6. If all works, get the new key cut
7. Enjoy my new key
Is this the correct procedure? Or do I get the new key cut first, move the chip over from the original into the new key and then pair the new key. Zambezi Silver Range Rover (2010 Autobiography Facelift)
Java Black Range Rover 4.2SC (Westminster)
Mercedes Benz GL450 4Matic (X164)
Mercedes Benz E320 CDI (W211)
Mercedes Benz 300SDL (W126)
Lexus LX470 (J100)
Lexus GX470
Audi A8L (D3 Chassis)
Post #257442 3rd May 2014 5:27am
daveo
hi, get the key blade cut last, if there is a problem with the key they will not take it back if the blade is cut.. V8 facelift Range Rover Autobiography 22" wheels.
Post #258332 8th May 2014 10:40pm
Jmelvinbath
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Hi
I have 2003 Vogue.
Can you still get these keys? and if so, the bit you were talking about removing from the car to program them properly... can one of you guys do this? and if so how much is it for two keys programmed and everything so they work like the originals?
Thanks guys
James
Post #259048 12th May 2014 7:30pm
Winchester101
The new keys work great you need to talk to Davo
He has also got a couple of videos here on the forum 1994 softail full stars n stripes custom harley davidson
Post #259059 12th May 2014 7:56pm
daveo
hi all, new order going on over the weekend
if you want in then please email me pm me
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #270452 12th Jul 2014 8:46pm
