![]() | Home > General (L405) > Electric tow bar |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
on/off? not sure what you mean , the boot switch retracts or brings the TB out ? Far to many gone... |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
There are two switches. One to turn the tow bar mechanism on and another to swing it in or out. You are meant yo press one to turn it on and then the other to swing it out. When I press the on switch I do not get a green light to say it is on and the deploy switch does nothing. |
KeithG934 Member Since: 31 Jan 2014 Location: Burnley Posts: 25 ![]() ![]() |
Mine seems to work fine as per handbook - tested it again this morning > on/off switch > green light > deploy/stow button. Not sure I'm getting what I would call 'warning tones' - more heavyweight motor sounds of movement and reassuring clunk when it's in place! Trailer electrics socket also there but haven't tested that wiring yet. Guess if you're not getting green light then refer to dealer?
It seems as if it's broken. Back to the dealer again |
Has it ever worked ? if not has it been enabled by the dealer at PDI Far to many gone... |
No. This was the first time I tried it. If I have the ignition on I get a red LED showing on the on/off switch so there seems to be power to the switches but other than that nothing. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
thinking outside the box here, is the the engine running when you try cos it might need full voltage to operate.. ... - .- -.
should not need ignition
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
You can now buy a non electric towbar for the L405 which is about time, forcing owners to spend the £800 on build for the electric one was a bit of a con.
The red light is on the on/off switch if the engine is running or ignition is on. I assumed this was to tell you the tow bar would not deploy in these circumstances as the instructions say to do it with the ignition/engine off. Anyway booked into the dealer tomorrow so we shall see. |
Loose wiring was the issue |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I keep reading a few niggles on the L405. I know it could be expected on a new vehicle but not on a £90k car ? Is this where I put the car details and a bit about myself ?........ |
[quote="RRUK"]You can now buy a non electric towbar for the L405 which is about time, forcing owners to spend the £800 on build for the electric one was a bit of a con.
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
I have the deployable towbar and it is worth every penny. Especially if you ask the cost of a retro-fit genuine one at he dealer.
