![]() | Home > Technical (L322) > Technical Bulletin; Smokey TDV8 Engine Modification |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Yes there is something on here regarding this - I remember reading about it 12 ish months ago - only one occurance from memory - the search function should find it for you |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
I put the details you gave in your message into the "Google search engine" ,and got all the necessary info.
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
Please see bulletin cover for reference.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
what exactly would you like to know?
Thanks for the advise Adigorn. The vehicle is still under warranty. But my concern is that the Budapest official LR service has very little expertise in this regard. Moreover although still under warranty mostly I have to persuade the staff to do anything and if they are in good mood and kind enough they might take a look! |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
I had a similar problem last year and asked my dealer to look at it and mentioned this known issue. He said they were aware of it and knew what needed to be done and they would sort it out. However, when I got the car back none of the invoices given to me mentioned whether this was the fix used or something else and the dealership that fixed it have never bothered confirming when asked.
1 all steps of modification are in service procedure
Thanks for all the great contributions and advises. Until now I was not sure whether I sould go for it or not... But now after receiving these expert answers I made up my mind and go for it.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
My vehicle is currently under 'Land Rover Extended Warranty' and one of the exclusions is 'exhaust systems including diesel particulate filters.' Is this an 'exhaust system' fault - i.e. am I going to be screwed over as I've heard it's a big job? |
I`m just ahead of this job, but I spent the last few hours translating the bulletin, just in case if anything would not be clear at the dealer/service! |
Thanks. Yes fingers crossed it is covered. My vehicle is in the affected range - I'm surprised that the dealer didn't just sort this out? Or is it not an official recall/service action? |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
Have the same issue on my 47k 2012 , dealer was vague on the service bulletin detail but said it would be either Land Rover or the warranty that will cover it. I have an oil leak and weeping rear dampers too. Don't like the sound of a dealer fitted tapped oil pipe to the block. 2012 4.4TDV8 VSE
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 ![]() ![]() ![]() |
My main dealer said that there wasn't an official JLR recall note on this, and that a) they couldn't advise if the modification had already been done or not on mine, and b) they wouldn't do any work without demonstrable symptoms (as they won't do proactive works).
It's not a recall but a service bulletin. The dealer said recalls are generally safety issues. I wonder if most owners notice, it was a friend following me that flagged it up. I'll report back if the upgrade is covered by LR or the warranty. Either way it should be leaking oil through the turbos. 2012 4.4TDV8 VSE
